To prove overunity, to the skeptics on here
Started by guest1289, February 16, 2016, 08:49:57 PM
guest1289
 forest
QuoteI believe Earth magnetic field is induced.
geodynamo
https://en.wikipedia.org/wiki/Dynamo_theory
  It seems the actual origin of this induced magnetic-field is
QuoteTidal forces between celestial orbiting bodies cause friction that heats up their interiors.
    Makes me wonder if this occurs between electrons and protons/neutrons,  or between atoms, or between materials.  I had read theories wondering that if you could completely insulate any material, then it should build up heat,   but I doubt that any material exists that could completely insulate something,  it all leaks via radiation.
     It would be a good idea if someone here  starts up a  thread,  on the  magnetic-sputtering  idea,  and  maybe include the words  'magnetic-sputtering' ( or spray ) in the title and maybe include the words 'dynamic'  magnetic-fields' from 'static magnets',   since people with knowledge about that wouldn't think to look at a thread like this.
   The main idea is to put things on, or coat the surface( or, in the original mixture ) of a permanent-magnet,  with something,  to try and cause a constantly changing, dynamic, magnetic-field,  even if the movement is very small.
   The material to cause that effect could be piezoelectric( like crystals ) or ferroelectric, or even permanent'magnets made of another material( to see what the incompatibility causes ).
    But what about coating a magnet( or somehow mixing ) it with superconductors like the different versions of graphene, and stanene( which hasn't actually been created yet ),  since superconductors eject  magnetic-fields,   maybe the  time-difference  between  an-ejected-field  and the field of the permanent-magnet  could cause a sufficiently large enough permanent-motion.
     Could the time-difference(  some difference in electron-spin ) between 2 separate magnetic-fields,   cause a sufficiently large enough permanent-motion.
    Thats a reason why  full-levitation,  just by using  permanent-magnets,   interests me so much.
    (  I posted a lot of designs on how easily that should be achieved, and it doesn't contravene  earnshaw's-theory,  because the levitation is not stable enough,  even though it does remain fully-levitating  )
       But it occurred to me,  that if you'd have a large-neodymium-magnet  fully-levitating  from the fields of static-permanent'magnets,    that any tiny movement by the fully-levitating-large-neodymium-magnet,  would be greatly amplified at the  outermost-tips  of it's magnetic-field ,  turning it into a useful source of energy.
(  also, maybe you could coat the surface of a magnet with tiny magnets that are somehow fully-levitating,  and then that causes a bigger constant-movement,  and then that causes a bigger constant-movement,  and that cycle repeats until the movement is big enough to generate useful energy  )
guest1289
guest1289
QuoteBut it occurred to me,  that if you'd have a large-neodymium-magnet  fully-levitating  from the fields of static-permanent'magnets,    that any tiny movement by the fully-levitating-large-neodymium-magnet,  would be greatly amplified at the  outermost-tips  of it's magnetic-field ,  turning it into a useful source of energy.
   The Amplification Of The Oscillating Magnetic-field Of A Fully-Levitating Permanent-Magnet
      So this  oscillation  is amplified at the very outer-tip( point-x1 ) of the magnetic-field( measurable-field ) of a fully-levitating permanent-magnet( magnet-x1 ) just levitating on the fields of other permanent-magnets( via the different simple methods I have posted ).
      Now what if you used  point-x1  to cause another  fully-levitating permanent-magnet of the same size as magnet-x1,   to oscillate more than it normally would,  and then keep on adding more and more levels of magnets further amplifying the oscillation,  eventually the oscillation would be big enough to produce useful energy.
