Here is my claim to the prize Mother Natures power supply
Started by MeGaFaRR, February 17, 2016, 05:09:00 PM
conradelektro
@MeGaFaRR:
Your three videos at least show that you build something. Fine, you do not have a working model, but you hope to have one soon. Well, I accept that. Premature ejaculation can happen in all ways of life.
Since you now know how to use YouTube for showing your work, we can look forward to regular updates.
May be you care to tell us, what the machine under construction will show? What will you measure, once it starts turning?
Something will turn, I am sure. But what is your goal? What measurement would prove your hypothesis? Will you measure torque or Watts?
Once your contraption turns, people will be able to tell you what to measure or what tests to do.
Greetings, Conrad
gotoluc
Quote from: MeGaFaRR on February 17, 2016, 06:15:39 PM
as I have stated here already that i have a working model and everything that i have found and asked about, proves that i am right.
Hello Frank,
could you so kindly make a video of your working model so we have a better idea of what you are presently building.
Thanks for your time.
Luc
AlienGrey
How a bunch of gears can imitate a snails shell, i shouldn't wonder !
Some thing wierd about this or is it me ?
wattsup
@MeGaFaRR
2 things.
1) Try and figure out a better resolution for your video camera so when youtube renders it you will have more image and less black sides. Should be a simple thing to do.
2) Hmmmmmm. I had done so many trials with those exact gears. They are very finicky and that increases with the number of gears in a given set, to say the least, but at least your gears are held with double bearings. Anyways, I will be curious to see what your strategy will be for gear ratios. Very noisy as well.
wattsup
MeGaFaRR
My machine only proves my concept that "I CAN REDUCE THE ENERGY REQUIRED TO ROTATE A FLYWHEEL TO FULL SPEED OR BEYOUND OF ANY POWER UNIT AND/OR INCREASE THE OUTPUT OF STORED ENERGY IN A SET OF FLYWHEELS" done.
http://youtu.be/e1a2gGSAztI
