HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
0 Members and 23 Guests are viewing this topic.
Sergh
I do not understand how Zografos converts hydrogen into electricity. Membranes do not allow to be obtained a large current and voltage  by a simple method.
This patent can clarify this, with using Circuit 3, but probably it is not so easy as described:
https://patents.google.com/patent/RU2409704C1/en
QuoteThe chemically pure water at a temperature of 25 ° C for about one to 5 × 10 September molecule dissociates according to the scheme 2 O↔N H + + OH - [Physical Encyclopedia.   T.1, M .: «Soviet Encyclopedia", 1988, s.296].  When exposed to varying electric, magnetic and electromagnetic fields to water (aqueous electrolyte), the frequency and direction selectively effects affect the degree of water dissociation.   The mechanism of this influence is explained as follows.    Vibrations of molecules - one of the basic types of intramolecular motion, wherein there is a periodic change in the relative location of the nuclei of atoms constituting the molecule.   The water molecule has two valence vibrations and one strain [Physical Encyclopedia.   V.2, M .: "Soviet Encyclopedia", 1990, s.405].  In addition, the atoms in interaction with each other in a condensed medium to which the liquid and solid state, always acquire electric charge, becoming positively or negatively charged ions [Physical Encyclopedia.   Vol.1, M .: "Soviet Encyclopedia", 1988, s.694, 695].   Thus, atoms in a condensed medium can be regarded as mechanical mikroostsillyatory having a certain mass and electric charge.   When exposed to the condensed medium by an alternating electric, magnetic or electromagnetic field oscillating ions interact with these fields, forming a mechanical oscillating system.  If the natural frequency of the chemical element is a multiple of the frequency of the alternating field acting atom, resonance occurs at harmonics [Physical Encyclopedia.   Volume 4, M .: Scientific Publishers "Great Russian Encyclopedia", 1994, s.308, 309].  The kinetic energy of the resonating atoms increases, thereby increasing the probability of breaking of covalent bonds between hydrogen and oxygen, and the degree of dissociation of water increases.
   Experiments on the effects of alternating electric fields conducted in distilled water.  Of a plurality of natural frequencies of water molecules for resonance oscillations impact frequency used in relation to which the natural frequencies of oscillation of the hydrogen atoms relative to the oxygen atoms and oxygen atoms with respect to the hydrogen atoms are multiple.  By calculation using the method given in the article I.M.Kavitskogo et al. "Mechanism of impact modifiers when structure formation in ductile iron, spheroidal and compacted graphite" [Kavitsky IM, Rushanik BA   and Demidov AA  The mechanism of structure formation impact modifiers in ductile cast iron with nodular and compacted graphite // Ironshaper Russia, 2008. - №10 str.25-29] determined frequency, in relation to which the natural frequency of the hydrogen atoms relative to the oxygen atoms and oxygen atoms with respect to the hydrogen atoms It is a multiple of.   They are respectively hydrogen for 9,735 × 10 11 Hz and an oxygen 6,133 × 10 10 Hz.   Capabilities allow the generator used to operate at a frequency of 0.1 MHz to 3.2 MHz.  From this condition for the experiments on the effects on the water chose two frequency groups: the first group with a deviation from the multiplicity calculation of the oscillation frequency to the actuating frequency of the first significant digit of hydrogen and oxygen to 5%, the second group with a deviation from the multiplicity of more than 5% (see. table).   The frequencies of the first group: 0.106 MHz, 0.315 MHz, 1.64 MHz, 2.5 MHz.   The electricity consumption for the preparation of 1 m 3 of hydrogen when exposed to these low frequencies.
   The frequencies of the second group: 0.5 MHz, 0.7 MHz, 1.3 MHz.   Exposure to these frequencies less effectively.
kolbacict
green matrix. generator 24 Ghz. how did you do it? the dragon hates me. Can not see there. :)
p.s. Oh, shit,I did not see above. Is that the one?
Sergh
The generator works, but creates a lot of harmonics. Need another Gunn diode. Those that are - at higher frequencies. Perhaps this is the reason.
Diodes are ordered from the online store. Will be in a week.
Now I'm thinking about how to use this generator. He is very weak.
It is necessary to invent a microwave input into water without big losses.
kolbacict
yet they say the Gunn diode oscillator efficiency is small.
QuoteNow I'm thinking about how to use this generator. He is very weak.
place the diode crystal in water? why not, the voltage there is small.fill the resonator with water.
p.s. and if one of the resonators of the magnetron of the appropriate frequency is filled with water?  :)
kolbacict
