HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
NdaClouDzzz
Practice overvolting some small (very small!) electrolytic caps.
stivep
Quote from: Panos25 on February 24, 2016, 10:25:55 AM
There are two machines made from Petros Zografos.
One generates huge amounts of HHO and the other generates directly electricity.
The main principle of both machines is the same and they do not work with any kind of electrolysis.
The production of the HHO is done by bombarding water with high frequency electromagnetic waves in a scale of THz ( the exact frequency is kept secret).
The patent and schematics are here:
http://www.hellagen.gr/search/label/ΠΑΤΕΝΤΑ
site dedicated to the invention: http://www.hellagen.gr
The original link to the patent doesn't show any results.
Does anyone know where  to find  original patent in English.
Wesley
stivep
thank you for the link.
_____________________________
some additional information:
The main cause of sound attenuation in fresh water, and at high frequency in sea water (above 100 kHz) is viscosity.
Important additional contributions at lower frequency in seawater are associated with the ionic relaxation of boric acid (up to c. 10 kHz) and magnesium sulfate (c. 10 kHz-100 kHz).
https://en.wikipedia.org/wiki/Underwater_acoustics#:~:text=
That means  attenuation is a force and process that uses released energy to provide desired effect.
At different  frequency the effect will be characteristic to  already known phenomena . And that is why inventor keeps  frequency in secret.
__________________________________
Terahertz waves from electrons oscillating in liquid water:
QuoteIonization of water molecules by light generates free electrons in liquid water.
so all you need is just light, or concentrated light by Fresnel lens
QuoteIt displays a frequency between 0.2 and 1.5 THz, depending on the electron concentration in the liquid. The emitted THz waves originate from oscillations of the solvated electrons and their water ...
https://www.bing.com/search?q=THz+frequency++and++water&qs=n&form=QBRE&sp=-1&pq=thz+frequency+and+water&sc=1-23&sk=&cvid=2ACDDA7BE2404C289263B35A1BC3697E
Hit a thin layer of water with the right frequency of a laser and it can emit terahertz radiation; this is useful for several purposes, such as viewing your insides safely (x-rays are dangerous, so exposure must be strictly limited; terahertz rays are safe).
REMEMBER:
NOT  ALL "LIGHT" IS VISIBLE.  means not all photons are noted but they are there.
After you resonate  in THz antenna ray  and rectify  these electromagnetical oscillation you have DC  energy  ready to use
simple electrical energy for free.  - FE
Unfortunately  to some of you :
You can't patent it as it is here said  by me.
By law - invention must not be published by anyone prior to filing .
So if you do that, than I will get you "by the balls"
Wesley
stivep
tools to apply for  investigation of this  kind of FE
https://en.wikipedia.org/wiki/Terahertz_time-domain_spectroscopy
it can also  be done for 10- 50 dollars of investment
Light Unit Conversion Table  - These are general conversion factors.
Unit of measure :
Footcandles
LUX
umol.m.2s1 of PAR
moles/day (PAR)
Watts/m.2 (total energy)
________________________________________________
WM.2:
Watts per square meter (WM.2). A unit of measure of the amount of light energy hitting a surface that is in the range of 400-800 nanometers.
some other forms of measurement :
https://www.stouchlighting.com/blog/electricity-and-energy-terms-in-led-lighting-j-kw-kwh-lm/w
But that is just measurement of light intensity and energy ...
We are interested in how much energy is  converted to  EM wave and than to electricity and that gives you your FE.
Wesley
