HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
Sergh
By video.
1. Zografos most likely receives a mixture of oxygen and hydrogen.
How to separate a mixture of gases? Hydrogen is much lighter than oxygen, if you fill a vertical tube with the mixture,
hydrogen will probably accumulate at the top.
The oxygen is probably passed through the water and pump 1, then through the filter to be purified, but from what?
2. According to my experiments, zeolite powder is very volatile. It quickly clogs all pipes and valves, if you do not put good filters.
Silicone tubes become white and opaque due to zeolite powder.
hartiberlin
R2fpl and Sergh,
Many thanks for the pictures
please keep on to analysis this video
Many thanks.Regards, Stefan.
Sergh
https://forum-zougla-gr.translate.goog/topic/509-%CE%B7%CE%BB%CE%B5%CE%BA%CF%84%CF%81%CE%BF%CE%BC%CE%B1%CE%B3%CE%BD%CE%B7%CF%84%CE%B9%CE%BA%CE%AE-%CE%BC%CE%B5%CE%B3%CE%AD%CE%B8%CF%85%CE%BD%CF%83%CE%B7/?_x_tr_sl=el&_x_tr_tl=en&_x_tr_hl=en
As  the radiation approaches the critical point of decay, the more conductive the water environment becomes, as we understand that we are approaching the resonance point F. A
For water we can talk about stages of superconductivity in some phases of the process.
hartiberlin
Many thanks for the Greek forum which I did not yet know..
There he also writes about heterodyn oscillators and side Band frequencies
generation with his oscillators..
So I wonder if he also had it in this small toy box with these side oscillators at the outside wall of this plastic box...?? Did he use there also different frequencies so he could split the water more effectivly with his sum and difference frequencies ??
Normally for just one frequency , one pcb board at one wall should be sufficient...So he is probably also using 2 frequencies there, because he uses 2 oscillator pcbs..
Regards, Stefan.
hartiberlin
Also are you sure he is using a Nafion fuel cell to produce the output power? because George Schoell said he uses Gunn Diodes but maybe he-mixed that also up and Zografos used them only  for the input gigahertz frequencies, he uses to split the water via the caralyst...hmm..
