The resonance energy device by Mohamed
Started by hope-hope, March 02, 2016, 04:40:21 AM
hope-hope
Hello
the idea is to find the natural balance of Electricity, Don Smith call it energy balance.. attachment 1
**the 3 layer ETBC seem to be the solution to such problem, it also solve the induced electric field discontinuity, i tested this coil partially and it produced about 400 ° the temperature that melt the Soldering tin ...
the information given here is free for the benefit of mankind ... ** attachment 2
The semi-final prototype of a power generation device is the result of the engineering shortcuts of the Tesla model for line-less electric power transmission
Number 1 is the explanation with how the engineering abbreviation works as it appears that the Earth was missing from the extended Tesla binary coil. After integrating the Earth into the model we get an extended triple coil. The feeding points are AB and it is better to have single pulses such as a high pressure capacitor discharging with the spark space .. the electrons will flow between the two points AB but the remaining part on the right which is the extension will be subject to electrical induction and according to Lanz's law there will be repulsion in case of increased current - As it is known, electrons are small magnets and it is very easy to rotate them into a position of attraction, and this is the opposite of Lanz's law.
No. 2 We see how to prepare the conveyor, as there must be an insulator on both sides along the length of the space .. We divide the length by three and compress it until it is coherent and then we wrap this coil on a plastic cylinder as shown in Figure 3
The middle coil, which is ETM3, will be responsible for transmitting the inductive electric field, and this is the advantage of this coil over the ETBC coil, where the middle coil is a conductive wire and it is formed that cuts this field along the extension so this defect had to be corrected by using a carrier plate as we see that the ground in The geometric model calls for the necessity of this middle plate.
So far, there are no practical indications, only theoretical, but some characteristics have been tried.  attachment 3
attachment 4 + 5  explain itself
The 3 layer folded foil as a coil can be seen as a Tesla bifilar coil the middle coil is the connection for the two later ( upper /lower ) it's also a flat coil because the current flow in a straight line, because the magnetic field cancel each other the net voltage is zero between the first upper and the second layer it's also a single Tesla or a monofilar coil ...
at right and left we have an empty conducting surface, it's empty because no electric current flow there but it's a subject for strong induction from the middle reactor coil we can call it L2 , L2 is the key for energy amplification as we see magnetic collision appear in this geometry , magnetic electrons or voltage electrons will be deflected to the right or to the left along the way we are able to collect and harvest huge amount of power, the middle plate serve as a guard for the induced rotating electric field ...
in short this is a big success in OU sciences !!!!  attachment 6
hope-hope
Hello lancaIV
Iam doing a geometrical transformation from Tesla wireless transmitter into locally energy crafting system that work as a pump for electricity
i don't see any geometrical transformation from all the link you gave me ..
regards
Quote from: hope-hope on January 04, 2021, 09:28:29 AM
Hello lancaIV
regards
https://www.google.com/search?client=firefox-b-d&q=radiant+static+electricity
https://sites.psu.edu/passionmalencia/2013/04/09/radiant-energy/
                                                     https://www.psu.edu/
Static electricity is different from the current that powers everything we know. Static is created by the collection of excess charge on a surface. The discharge of this charge is what transmits energy, but it is not like current electricity. Static electricity is described as "sound waves of electrified air" (Clear Tech). This means that the energy is traveling as a longitudinal wave rather than a transverse wave (electromagnetic radiation and electricity as well as magnetic fields are all transverse waves). Longitudinal waves vibrate in the direction of the traveling wave. This means that the pressure of the way changes, whether it is air pressure from a sound wave of electric pressure from static discharge.
The potential of radiant energy as a source of power is unfathomable. It can perform similar tasks as electricity for less than 1% of the cost.  8)
Some technology, like Edward Gray's Electro-Magnetic Association Motor (Pulsed Capacitance Discharge Engine) have been created and successfully used. In search of renewable energy sources for the future, radiant energy might be an extremely viable solution. Plus, static electricity is fun. ;) :)
hope-hope
i still can't see any geometrical transformation  ;)  i just share what i think useful maybe someone find it interesting
