Mechanical Resonance (Projects)
Started by Magluvin, March 25, 2016, 08:01:12 PM
Magluvin
Stopped at Ace Hardware and spent more than I intended. ::) ;D
They had these stainless bars and I got them.
Put this together this evening. Home made tuning fork. I put the mags on the ends with opposing fields between. It changes the freq of resonance. She is just above 55hz.
Ok, bed time and will mess with it this week.
Mags
Magluvin
Oh, one thing I noticed today is when it is in resonance, if you hold the drive coil manually, it vibrates my hand the least, almost nill and can almost just sit there without the tape. Out of resonance you feel much more vibration and will bounce around if you let it go. So while playing, tape. ;D
Anyway...
Mags
DR.WHO
Your adding power to both coils ? That is not resonance ! You have to add power to one coil and both coils must resonate ! I fill you need to add a self resonating Basher free energy coil and in theory it will keep self resonating for ever on one single charge pulse ...
It can not self resonate with out this self resonating coil and I would like to see Tin mans transformer back in action to achieve the end result
What I see is mother natures secrets tat a bee and a humming bird and some Beatles have and that is a self resonating wing ! They just dont have enough energy to do what they do so resonance is the only way they can keep there wings moving constantly with out ever getting tiered.
When you have it self resonating with no battery than you truly have achieved something very important ! The frequency harmonic is going to be the key point to tune to.
Magluvin
Quote from: DR.WHO on April 26, 2016, 12:55:44 PM
I think your have it wrong on what Im doing here. What Im looking at is getting something to be in resonance via input to one coil and using the other coil as a generating pickup coil. So far I have gotten a higher voltage from the pickup coil than what is input to the other identical coil. Typically at these low freq if the 2 coils were set up as a 1 to 1 transformer, the pickup coil/secondary should only put out as much or less voltage than what was input to the driver/primary coil. So the mechanical resonator between the coils gives a step up transformer effect, of which is part of the investigation in these experiments.
Mags
Magluvin
Here is a vid of the new setup.  The mags are not the ones I used to get the higher voltage on the pickup coil, The big mags are next. Then with a change to the height of the tuning fork on the base, Im making stands for using the original speaker magnet assys from which I got the coils from. The length of the tuning fork allows for a more straight movement of the coils if mounted to the fork, so I think I can get the speaker mag assys to work, The previous setup had to much angle of movement. So this may work well. When thats done we should see some better efficiency on the in and the out.
https://www.youtube.com/watch?v=2OTyErrA9N8&feature=youtu.be
Mags
