Centrifugal Power Source: The Linevich Story
Started by Eighthman, April 02, 2016, 01:38:42 PM
ARMCORTEX
Quote from: citfta on March 30, 2017, 05:21:56 PM
I read through the PDF.  I see a serious omission in his theory.  He is ignoring the well known law of conservation of angular momentum.  The is the law that says as the center of mass moves out in a rotating body the velocity will slow down and conversely as the center of mass moves inward the rotating body will speed up.  This is the way figure skaters get to spin so fast by pulling their arms and legs together as closely as they can.  They also stop quickly by merely putting their arms straight out.
You can prove this law to yourself if you have a piano stool or other chair that spins freely.  Just sit in chair and have someone give you a spin while you have your legs straight out.  Then pull your legs in and feel the effect.  After you speed up then put your legs back out again and you will slow down.  Pull them back in again and you will speed up again.  If the bearings in the chair are in good shape you can do this several times until friction finally slows you down.  What ever you gain by moving the center of mass in you will lose when the center of mass gets moved back out.
Respectfully,
Carroll
Its easy to go by assuming.
Can you mathematically prove otherwise?
If so, do it and explain where was the mistake.
If not, you must admit that linevich has better mathematical skills than you.
Its difficult to disprove such documents without in depth study, just saying things like that
does not mean you carefully analyzed all aspects.
Me I admit that cant disprove or prove at the moment, so I refuse to comment on his paper.
                                 to reply #64: http://dlinevitch.narod.ru/Eng/pages_E.htm  it is not in Russian
                                                   Kanarev is refering Linevich.
                                                      centrifugal/centipetal : counterbalance ?
                                                      how many dimensions has time-space
Eighthman
It is difficult enough for me to read the math and concepts provided. The fact that they are translated makes it more difficult.  This is no one's fault, just language troubles.
Do you have a working link for the '25 watt to 400 watt' device?  The other links seem good.
Thanks
Eighthman
This is really wild and speculative stuff.
http://www.synchronizeduniverse.com/IUFO%20OUTLINE%20v23.pdf
read the section about Hall and the "Tall Whites". I think it's page 43.  He identifies this gyroscopic movement and precession as the very mechanism with which UFO's travel.  They use spinning photons within miles of optical fiber that surrounds their craft.
www.gratisenergi.se/Impulse_Power_Secrets.odt
#59:
https://www.xing.com/communities/posts/alternative-loesung-zur-energiegewinnung-1003340445
Der russische Wissenschaftler Edwid Linevich (Vladivostok) hat im August 2007 ein Patent für einen Unwuchtmotor angemeldet, der den Weg in zu einer umweltverträglichen Stromversorgung ebnen kann. Die Funktionfähigkeit des Motors wurde mit einem Testmodell im März 2008 unter Beweis gestellt. http://www.perpetuumobile.eu Die Testergebnisse sind erstaunlich:
Bei einer Leistungsaufnahme von nur 25 Watt entwickelt der Motor eine Leistung von 400 Watt .
http://web.archive.org/web/20080610065702/http://www.perpetuumobile.eu/
Arestov and Linevich are co-partners :  Permotors GmbH(~Lda.)/Austria
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=permotors&IN=&CPC=&IC=&Submit=Search
