An Experiment with compass needle
Started by vineet_kiran, April 07, 2016, 12:27:56 PM
vineet_kiran
A simple method to tap magnetic field energy
lumen
Can't work, if you tried to draw work from the needle to the disk, then the disk would rotate harder. Not free!
vineet_kiran
Quote from: lumen on April 07, 2016, 12:51:30 PM
If needle is straightaway connected to disk  then obviously disk rotation becomes harder because the disk and needle rotate in opposite directions.   Energy from the rotating needle has to be drawn out separately may be by mounting a  generator on needle shaft and energy from this generator should be supplied to central shaft by means of motor fixed to central shaft.
lumen
Quote from: vineet_kiran on April 07, 2016, 01:24:36 PM
Yes, but what does the generator connect to? One side is the needle and the other side is .......?
How about to another needle on the other side of the wheel and a figure 8 belt connecting them. That way one needle will work against another needle.
vineet_kiran
Quote from: lumen on April 07, 2016, 08:40:42 PM
I didn't  understand your question.  My idea is like this.  Please see the attachment.
