An Experiment with compass needle
Started by vineet_kiran, April 07, 2016, 12:27:56 PM
lumen
Your compass needle is stationary and the disc is turning the generator.
MagnaProp
I suspect lenz law in the generator's coils along with centrifugal forces from the large disk will keep the needle from staying aligned with the earths magnetic poles. I hope I am wrong.
vineet_kiran
Quote from: lumen on April 08, 2016, 01:34:19 AM
Compass needle is not stationary.  It has to rotate to align itself in N-S direction.
Quote from: MagnaProp on April 08, 2016, 01:58:53 AM
Earth's magnetic field is very week. Obviously the force of attraction between needle and earth's magnetic field cannot overcome lenz's forces and centrifugal force.  Hence I have suggested  a strong rectangular magnet at the base having same polarity as earth's magnetic field.   A very strong attractive force between strong permanent magnet and needle can overcome lenz's  as well as centrifugal forces.
Here the bottom magnet acts as external force and energy is generated by strong attractive force between needle and bottom magnet. (instead of needle, a strong permanent bar magnet can be used)
MagnaProp
Quote from: vineet_kiran on April 08, 2016, 04:31:39 AM
...I have suggested  a strong rectangular magnet at the base having same polarity as earth's magnetic field...
You mean like this image?
If you put large external magnets on each side of the big wheel, as shown in the image, to simulate a stronger earth magnetic field, then the needle will cause some drag as it gets pulled away from the external magnet that it is attracted to. Perhaps that drag is negligible as you also gain some energy when it gets pulled towards a magnet it gets closer to? So there is no net loss in energy to the large wheel?
vineet_kiran
Quote from: MagnaProp on April 08, 2016, 05:18:17 AM
The magnet has to be at the base, parallel to the ground / disc.   If you provide magnets on sides, obviously the needle experiences dragging force when it moves out of magnetic field which will not have any advantage as far as energy is concerned and it becomes like other non-functioning magnet motors available in the internet.
The needle should not move out of the magnetic field.    When disc is rotated w.r.t. earth's magnetic field the needle doesnot move out of earth's magnetic field because it covers the entire earth.  So, if you provide a base magnet as shown in the picture which is bigger than the disc,  the needle doesnot move out of bottom magnetic field hence there is no chance of dragging force.
The needle always tries to be in line with bottom magnet which is S-N.   Hence when main disc is rotated, the needle has to rotate  to align itself  in N-S direction.
