Free Energy from a UFO in Bible = Ezek 1:16
Started by that_prophet, April 19, 2016, 11:47:11 AM
that_prophet
SIMPLICITY AT ITS BEST
GEM = Geometrical Electricity Multiplication
(AC Electricity Multiplication using simple geometry of pulleys to multiply total rotations)
Come on guys and gals
Let's get with the program
This is the most super simple way of multiplying AC electricity
By using pulleys to multiply your total # of rotations
THIS WORKS, and it is so logical that it simply MUST WORK
You rotate a large pulley one time which only takes one spark of DC electricity to rotate
Which has a belt that also passes by many mini-pulleys with AC generators attached
These mini-pulley rotate massive amounts of time +
You can have 10s to 100s to even 1000s of these mini-pulleys
Leaving you with millions of AC cycles of electricity
All this AC potential is generated by one spark of DC electricity
With the massive increase of AC voltage from the many rotations
You would have unlimited potential for doing work = watts = current
(Let's use this Gift to not only restart our economies,)
(but to redistribute this new found wealth to the middle and lower classes)
(not to mention help save our environment=(no pollution)+building electronic filters = no costs)
(let along help end terrorism=not spending massive amounts of cash on oil=funds most terrorists)
(reduce cost of everything by lowering transportation cost by not paying for fuel=free electricity
This is God's Gift to man, to help us heal our land + water + atmosphere + economies
Not only can we stop polluting our atmospheres, land + waters with fossil fuel residues
But we can start fixing all of this pollution at practically zero costs  (zero cost to fuel once built)
By simply building industries to build the best electronically driven land+water+air filters
The best ones are the ones that cost the least in raw materials + the most in free electricity
This works by simply using one large circumference pulley, to gain the longest length of strap to run through many mini-pulleys by using the single rotation of a DC drive motor, (which only uses one spark of DC electricity) which is attached to, and driving a large 100cm circumference pulley for one full rotation. A belt/strap/rope/elastic or even a length of string in a pinch, is used to run around this large drive pulley, and then passing by one to ten mini-pulleys of one centimeter circumference, with AC motors/generators attached. These generators rotate 100 times each, and wind up massive voltage, that is needed-used to rotate your DC drive motor. These mini-pulleys rotate massive amounts of times, giving you more than enough AC voltage, (when you run through full wave bridge rectifiers), to give you the one single spark of DC electricity, that is needed to drive your DC motor one single rotation. These mini-pulleys, when attached to AC motors/generators, are just being used to wind up a massive amount of voltage, which more than meets the only one spark of current, so they give practically no torque resistance, (torque is generated when you need current + voltage = wattage = power = resistance).
You only have to put one spark of DC electricity into a DC drive motor to rotate this motor one single time, which turns an attached 100cm circumference pulley. This pulley gives you 100cm of moving belt/strap/rope/elastic or (even a length of string in a pinch) to work with (one rotation of 100cm circumference)
Then you run this 100cm of moving belt through 1-10 mini pulleys, (of one cm circumference) If you attach AC motors/generators to each of these mini pulleys, you would get,,,1-10X100=100-1000 cycles of AC electricity out, which is massive voltage-potential + major pressure, compared to the mere 1 spark of DC electricity that is needed as input, to start this mechanism running =(big time free energy=can get massive current potential). Think of how easy it is to rotate disconnected electric motors, when they are just winding up massive voltage,,, oh yah, and just what is it that we needed to run this drive motor anyway, just one spark of current + massive voltage-(pressure) to rotate the large pulley one single time. You now have a set of self-powering AC + DC generators, that produce free electricity forever, or until your bearings dry out + If you used electric bearings, you may actually be able to make the first True perpetual motion machine.
Just think of these AC generators as running freely, so they run with no drag = like empty motor cycles = no back pressure = no current used or needed,(just one spark). They are just winding up massive amounts of voltage, in order to rotate your large drive pulley, which is attached to your DC motor, and you only need the one spark of DC electricity, for the one single rotation. You need + get this spark of DC electricity after you run your massive AC output through full wave bridge rectifiers = (4 diodes) to convert your AC voltage into one spark of DC output (as you only need one spark of output to drive your DC drive motor) = You now have created a self-powered,(perpetual) mechanism that produces unlimited free AC+DC electricity. (To get access to these AC+DC power supplies, you only need to run wire leads from both of your AC+DC outputs) + these perpetual power supplies should give you as little, or as massive amounts of current=power that you need. This is because the larger the current that you put into this mechanism, the larger the current = power that you will get out of this mechanism.
But you don't need big money to do anything with this. You only need an AC+DC motor of the same voltage, full wave bridge rectifiers=(consisting of 4 diodes), some wiring, a large and at least one small pulley, could have many more=increasing multiplication factor, and a belt, strap, rope or even a tied length of string in a pinch, to connect the pulleys together. you drive the large pulley with your one spark of DC electricity. The circumference of your large pulley is the length of belt that you have to work with, that you run past your mini pulleys. This will wind up your mini pulleys with massive amounts of voltage, which is more than enough to turn your DC drive motor just once. Now you have a perpetually running power supply, or supplies, because you now have both an AC+DC motors/generators running, that you can tap electricity off of. You can get this mechanism to run by simply giving the large pulley a slight 1/4 turn by hand. This would rotate your mini pulleys with AC generators on them 10s to 100s of times,,, giving you more than enough voltage pressure to rotate your DC drive motor once= (needs only one spark of current)
Sorry, but I happened to be disabled + unable to work with my hands enough to build this myself, and I happen to be living on CPP disability, so I do not have sufficient funds to hire anyone to build this for me. Unless I can find a free electronics simulator, I cannot build this dirt simple contraption. I was hoping that I could explain how super simple it was to build, and be able to talk someone else into building this. I put it on the web to declare ownership of this technology at http://free-energy.yolasite.com/ so that nobody else can patent it, so this is truly a free energy technology, and will cost you nothing if you build something that can make you money.
I first conceived=(saw it in a Vision) this technology during the early 2000's, thinking of a 10 speed bicycle going uphill in tenth gear, (few rotations of pedals) and then back downhill in first gear (massive rotations of pedals)-where pedals = AC motors. This only works because with AC electricity, where the more rotations that you get = the greater amount of AC electricity you gain. This is because you are running up a very significantly high voltage,(work potential) using your massive AC rotations. I then published this on the web at: http://free-energy.yolasite.com/ to make sure that nobody else could patent it,(so that only I can patent it + I will not) as how could this Truly be free energy, if you had to pay patent fees for using it,,, lol.
The only reason that this technology has not been used earlier to create free energy for us,are the millions, if not billions of fallen angels + evil spirits, trying desperately make sure, that mankind never discovers this super simple technology, which is His Gift to mankind, which He laid out for us way back in Ezekiel 1:16. Please don't listen to the evil forces telling you that torque is a problem free running AC electric motors take practically no torque to turn. These are free running AC motors/generators because they are just being used to wind up massive voltages, and need to produce only one single spark of current, to put back into this free energy, (AC electricity multiplication) system.
PLEASE BUILD THIS PROOF OF THIS FREE ENERGY TECHNOLOGY = I believe that my Lord has Shown me how simple that GEM=Geometrical Electricity Multiplier can be proven with a simple headlight mechanism for any bicycle. First you flip the bicycle upside down, to have the tires running freely in the air, and even though one generator might be all that you would need to cause this mechanism to start running perpetually, I think that we best attach 4 generators to the same tire. Now you will need to get a DC motor, and attach it to a medium pulley+(1 inch or more circumference), then use a big,(thick) elastic, or length of belt, strap, rope or even string, to go around both your pulleys, and then some smooth round part of your rear cog or cogs=(in a 1-3-10 speed) even if you had to pad the sprockets with duct tape.
generators for bicycles are hard to turn, but if you just put the right voltage AC motors with rubber pulleys mounted to the rim, you would get the rpms with practically no resistance.
Paul-R
This is just a waste of this site's bandwidth.
For Heavens sake, Stefan, BAN THIS PERSON.
Dave45
Religion and science are intermingled more than you know this is a symbol that represents Ezekiel's wheels
Dave45
There is a field that travels along the outside of the wire.
If you look at the symbol and imagine that each curve is actually a loop or coil you will see that the field is cut at each intersection where the coils meet, this creats a vortex in the center.
Dave45
Build it then add a high voltage power source with a anode an cathode above and below the coils.
