Interesting free energy experiment.
Started by TommeyLReed, April 26, 2016, 09:53:16 AM
Cherryman
Lidmotor has done a kind of replication.... of the SAME video
But he " forgot"  the flywheel .  : )
https://www.youtube.com/watch?v=tWuVUDjWGSo
TommeyLReed
Hi Cherryman,
I would question that video due to the fact of super capacitors .
I think most people have not fully understand what my project would do.
The drive motor would not rotate when the power is cut off due to one way bearing step up. In other words as the motor increase the flywheel rpm's and then is turn off, the flywheel goes into free spin without rotating the dc drive motor.
This is when power is pulled from the flywheel for a few seconds, at that moment the generator stops pulling power and kicks on the drive motor back up to the rpm's the flywheel was.
This also would make it more efficient then having a constant mechanical load from the drive motor while the flywheel spins.
Tom
Temporal Visitor
Quote from: tinman on April 28, 2016, 12:18:05 AM
Perhaps stop trying to be a scientific  guru ,and just provide one example of any type of flywheel producing enery-as you claimed.
Cryptic talk and circle walking really go's no where.
Brad
Quite a paradox you just set up.
Here is a photo - no words.
Because like most of what I do - the rest is pure applied science - lots more.
Nothing cryptic about it.
Hope it satisfies you, since there is no changing what I am: you can watch it in "sign language". https://www.youtube.com/watch?v=-vaeKI5yXnQ
Tom is on the "write" track. Having "been there"; wrong turns lay ahead and he will learn by "science".
tinman
Quote from: Temporal Visitor on April 28, 2016, 07:19:03 AM
First up.you need to reduce the size of your picture's, as now the page has expanded 3 pages wide.
QuoteQuite a paradox you just set up.
I set up no paradox-i asked you to provide an example of a flywheel producing energy.
QuoteHere is a photo - no words.
This is your proof?  ::)
QuoteBecause like most of what I do - the rest is pure applied science - lots more.
Science says that a flywheel is an energy storage device--not an energy production device.
So i ask once again,are you going to provide proof to back up your claim that a flywheel is an energy production device?.
QuoteTom is on the "write" track. Having "been there"; wrong turns lay ahead and he will learn by "science".
Nothing cryptic you say?--->!!write!! track  ???
Yes,Tom will learn that science is correct,in stating that a flywheel is an energy storage device--not an energy production device.
Brad
citfta
TV,
As Brad has asked please resize your picture.  You first have to edit your post and remove the picture.  Then you can use a picture conversion program to resize it and then reattach it to your post.  I like FPC (Free Photo Converter).  As the name says you can download it for free and it is easy to use.
Carroll
