The theory of magnetic generator
Started by Igor48, April 27, 2016, 08:24:23 AM
Igor48
The angle between vector's motion and vector's magnetic field must be minimal.
Igor48
Increase the area of interaction of stator and rotor's magnets.
Igor48
Rotor's axis is not perforating on the picture below.
The stator's magnet rotates with the rotor regardless of magnetic force field of both magnets. You can check it with experiment:
The cube and circle magnets are on the piece of plastic. Lower magnet A is rotating around the axis so upper magnet A rotates with the lower one. Cube magnets are bounded with the magnetic field, they rotate together. Circle magnets are bounded with the magnetic field but the upper magnet B does not rotate.
Experiment showed us that the rotor and stator's speed can be different and do not cause deceleration of reducer.
Igor48
