Is The Earth A Flat Round Disc or Is It a Round Spherical Globe?
Started by gravityblock, April 28, 2016, 12:14:07 PM
Is The Earth A Flat Round Disc, Concave, or Is It a Round Spherical Globe?
The earth is a flat round disc!
The earth is a flat round disc with a dome!
The earth is a round speriical globe!
The earth is concave!
gravityblock
Heliocentric model debunked with evidence!
The continuation of looking at the terminator line advancement on the earth absolutely shows with 100% certainty that the heliocentric model can not be true. There is no way with the current science model to "advance" the terminator line for one half of the earth and not the other in the current heliocentric model.
The time and date map doesn't match the globe. It matches flat earth and the Yin Yang Radial Oscillator Model as previously posted.
Gravock
gravityblock
Quote from: verpies on May 03, 2016, 10:19:00 AM
but if the electromagnetic waves ares reflected so, then their angle of incidence = angle of reflection and many receivers could not receive the same ground transmitter when looking up at different angles (from different geographic locations, latitudes, longitudes and altitudes).
Look at how much the 2 quadrillion watt laser light dispersed over Chicago's Soldier Field and beyond after bouncing off the firmament.  Dish Network transmits their signal at less than 500 watts per channel, so the much weaker signal will be dispersed over a much wider area than the 2 quadrillion watt laser.  The parabolic dish concentrates this very weak signal at the focal point where the LNB is located to increase the signal.  The larger the parabolic dish, the higher the signal strength will be.  This is how many receivers looking up at different angles can receive the same ground transmitter.
Gravock
verpies
Quote from: gravityblock on May 06, 2016, 04:47:36 AM
The laser light was emitted for how long?
How long did the glow over the Chicago's Soldier Field last ?
Also do you mean that the angle of laser's incidence <> angle of its reflection ?
gravityblock
Quote from: verpies on May 06, 2016, 05:06:23 AM
The laser light was fired for how long?
The angle of the reflected signal is the same as the angle in which the signal is being transmitted by the virtual satellite, so what's the problem?  In the Northern States, the dish will be pointing at a lower angle, and in the Southern States, the dish will be pointing at a higher angle.  On the west coast, the dish will be pointed more towards the east, and on the east coast, the dish will be pointed more towards the west.  The duration of the laser light that was fired is irrelevant.  If it was longer than the glow in Chicago, then whose to say the laser remained in the exact same position.  If it was shorter than the recorded glow in Chicago, then whose to say the firmament didn't absorb and release the energy at a slower rate due to it's high energy levels.  I know, that may sound absurd, but we really know nothing about the "God Particle" that makes up the invisible glass-mirror like structure that is above us.  Watch those so-called nucleaur bomb tests.  It does appear that it absorbs some of the energy as the energy is pushed out radially.
Gravock
gravityblock
Verpies,
The two main virtual satellites for Dish Network is 110ow and 119ow.  The angle of incidence will be 110oe and 119oe.  The meridian 110° east and 119o east of Greenwich is a line of longitude that extends from the North Pole across the Arctic Ocean, Asia, the Indian Ocean, the Southern Ocean, and Antarctica to the South Pole.  The North Pole is where the ground based antennas are located, and Antarctica is where the edge of the firmament dome is located that reflects the signal across the States.  As you can see, the angle of incidence = the angle of reflection which is 110 and 119 respectively!  This is absolute proof there's no satellites orbiting the earth and absolute proof the earth is a flat round disk with a dome!
Gravock
