Is The Earth A Flat Round Disc or Is It a Round Spherical Globe?
Started by gravityblock, April 28, 2016, 12:14:07 PM
0 Members and 27 Guests are viewing this topic.
Is The Earth A Flat Round Disc, Concave, or Is It a Round Spherical Globe?
The earth is a flat round disc!
The earth is a flat round disc with a dome!
The earth is a round speriical globe!
The earth is concave!
profitis
"The intentions of nasa is to
deceive you"
Not me.atleast not me anymore.deception is a lie,a lie is negentropic.entropy see's straight thru it.if someone holds a mirror upto you and your aware of it simply dive around,underneath,over,or hell dare I say it,,,through the mirror onto the other side.the mirror is only silvered on on  one side,that's its weakness
profitis
"You don't want your illusions
destroyed, because you want to continue walking
after your own sinful desires.  This thread is not for
you, because the truth isn't convenient for you!"
Life is an illusion,who are you going to complain to about that
scotty1
hi all.Thought i'd throw my two cents in.
Here is a pic of a test I did on the spring equinox (i'm in Australia)
I made a sundial flat to the ground with a vertical gnomon that was one inch high......25 mm....
During the day I marked the end of the shadow for each 1/2 hour while I was at work.
It can be clearly seen that points of the end of the shadow all form a straight line on that particular day.....September 22.....and it will be the same on March 21 as well.
The fact that the shadow points all form a straight line proves that the earth isn't flat!!!!
If the earth was flat and the sun moved over it, then the ends of the shadow on my sundial could never make a straight line.....NEVER!!!!
The only way it could, is if the sun changed it's height over a flat earth......and that is not what the flat earth models show.....so....the simple answer is that the earth is spherical and not flat!!
September is approaching so anyone who wants to prove this themselves can easily do so.  ;) ;D
It's not rocket science.......just true empirical science.... 8)
Scotty out.......
btw......if you subtract the September angle from the June angle you will get the earth's tilt exactly......even with a tiny setup like I used!!!  :) ;D
gravityblock
Quote from: scotty1 on July 30, 2017, 06:00:19 AM
Scotty out.......
You didn't put much thought into this, did you?  The sun's apparent height does change during your experiment.  Let's use a street light as an example.  As you move towards the street light, then the street light's apparent height will increase and cast a shorter shadow.  As you move away from the street light, then the street light's apparent height will decrease and cast a longer shadow.  Likewise with the sun.  As the sun is coming towards the vertical gnomon (on a flat earth), then the sun's apparent height will increase and cast a shorter shadow and as the sun moves away from the vertical gnomon (on a flat earth), then the sun's apparent height will decrease and cast a longer shadow.  This is exactly what we see in your experiment and on the flat earth.  The straight line actually proves a flat earth and not a globe!
If the earth was a globe, then a vertical gnomon on this curved rotating surface could never make a straight line with the ends of the shadows on your sundial....NEVER!!!
Globalists proving the flat earth!   :) ;D
Thanks Scotty,
Gravock
