Bike runs on water 100 % - No Gasoline - Microwave Pulse Generator Water Split
Started by hartiberlin, May 04, 2016, 02:29:43 AM
EdChe
Here is another article concerning the 13.56 MHz frequency.  http://www.i-sis.org.uk/canWaterBurn.php
Following on one of the references, I was rewarded with another mainstream news story (from a while ago) on the subject.
Salt Water into Fuel - https://www.youtube.com/watch?v=aGg0ATfoBgo .  Continuous!  Could this be used for the cars?
Can radio waves be added to existing cells to increase output?  They use a lot less electricity (article said 300 Watts), so it wouldn't be out of the question...  Happy researching!
hartiberlin
I got some information from his German associate:
Did you know, that Zografos uses GUNN diodes to rectify his TerraHz RF radio waves to DC to get a very high efficieny new kind of Fuelcell ?
On his RF fuelcell he showed in the greek TV channel, he uses these 6 piston capacitors to tweak the resonance of the TerraHz resonance via
mechanical adjusting and uses his great RF measurement equipment to maximize the amplitude of the TerraHz oscillations and then uses 6 Gunn diodes
to rectify the TerraHz RF currents to DC power...
This way, he got a real good DC power output that he uses to power a DC to AC inverter to run all his equipment...
Also I was told that this hydrogen from his high frequency electrolysis acts like a "metallic conductor",
so the hydrogen ions ( probably H+ or H3+) are very conductive...
So this is probably the basic secret...
Also he had a basic cell video on his channel, where he showed just a simple RF electrolysis cell powered by 2 dissimular metals like Magnesium and
copper, so about just 1.5 Volts  and then used 2 gunn diodes to rectify the RF output of the H3+ TerraHz ions oscillations to run 2 fans and also in another video light up a  Fluorescenz light bulb ... and runs 2 fans with the output.
Regards, Stefan.
hartiberlin
Okay, here is the exact video, where you can see it:
In this video at:
https://youtu.be/twYbr-ZSU0g?t=33m48s
min 33:48
he starts filling in into his small box some saltwater .
Inside the box he has 2 dissimular electrodes, which produce a galvanic voltage of probably around 1 to 1.5 Volts like
using Brass and Magnesium plates or something simular...
This voltage powers his 2 circuits small GigaHz or TerraHz RF oscillator, that splits the saltwater into
High Frequency TerraHz  oscillations.
Then on top of this small box sits 2 reactangular electrodes, that receive the splitted Saltwater Ions, which are highly conductive
and still are vibrating in this TerraHz range...
To these electrodes are 2 gunn diodes soldered onto these electrode boards, that rectify these TerraHz waves into normal chopped DC output
which are running then these 2 propellors....
Okay, the dissimular metal electrode plates are consumed, but the output from the 2 gunn diode boards is much higher than the galvanic power
used to power the 2 RF oscillator boards from the galvanic output of just about 1.5 Volts and a few Milliamps....
Hope this helps to nail down the great invention of this great new "fuelcell" via gunn diodes rectifying the TerraHz electrolysis output waves...
Regards, Stefan.
hartiberlin
I added a few more infos here on my Steemit.com account:
https://steemit.com/news/@overunitydotcom/how-the-water-to-electricity-petros-zografos-free-energy-fuelcell-system-is-working-from-hellagen-gr
Please upvote it, if you also have already a Steemit account.
Many thanks.
Regards, Stefan.
P.S. We have to find out, how we can best  rectify these GigaHz or TerraHz waves via these special diodes.
Maybe Zografos is also using Gunn diodes to maximize the Resonance of the GigaHz or TerraHz wave via his piston capacitors and then uses
Pin or Tunnel diodes or other special RF diodes to rectify the RF currents from his RF electrolysis to DC output power...
In his latest prototypes he already got about about 800 Watts of output power and there is a rumour that he now works on a 25 KWatts system.
Void
Quote from: hartiberlin on October 10, 2017, 03:51:54 PM
Hi Stefan. I  know little about microwave electronics, but when I read a bit about Gunn diodes it
seems that they are not really diodes, as they don't have a PN junction, and it seems they
are more used in microwave oscillators and amplifier circuits. If this guy is rectifying microwave
AC waveforms to DC, then I would guess that it is not using Gunn diodes to do the rectifying,
but as I say I am not knowledgeable about microwave electronics so I could be wrong about that. :)
As you said, if he is rectifying microwave frequencies to DC, maybe he is using some other type of
special diodes, although I don't know what kind of diodes can work as rectifiers at microwave frequencies.
This site might have some useful info:
https://www.microwaves101.com/encyclopedias
Some excerpts:
https://www.microwaves101.com/encyclopedias/pin-diodes
PIN Diodes
"A PIN diode only acts like a rectifier at low frequencies. At microwave frequencies, the IV curve undergoes a change, so that it behaves like a resistor, whose resistance value is determined by the level of DC current that is present in the I-region. Thus a PIN diode is essentially a DC-controlled high-frequency resistor. Just as important, if no DC current is present, the diode behaves like an open circuit."
https://www.microwaves101.com/encyclopedias/tunnel-diodes
Tunnel Diodes
"In 1958 Leo Esaki, a Japanese scientist and Nobel Prize winner, discovered the tunnel diode phenomenon. If a semiconductor junction diode is heavily doped with impurities, its I-V curve will have a region of negative resistance (the slope is negative, or downward). Such diodes are called "tunnel diodes", and have broad applications in microwaves. This region has been exploited to create oscillators, but it also makes a very efficient detector. Why the word "tunnel"? We'd have to resort to quantum physics to explain that, but we won't, because no real microwave engineer cares!"
