Bike runs on water 100 % - No Gasoline - Microwave Pulse Generator Water Split
Started by hartiberlin, May 04, 2016, 02:29:43 AM
Kator01
Pomodoro,
what about this picture ( on the same website ) ? There seems to always be some orange colour there.
I think the clear almost unvisible flame only appears at high gas-velocity of a burner
But of course,  in the other video-demonstration he is using salt-water
regards
Kator01
hartiberlin
Quote from: pomodoro on May 06, 2016, 05:43:35 AM
I have just replicated the test tube experiment with methanol (1 carbon) and isopropanol (3 carbons). I simply heated a few mls of the alcohol in a test tube with a heat gun and lit the boiling vapor. Methanol buns clean with no yellow, isoprop is very yellow. I don't at the moment have ethanol (2 carbons) to try. When I stop the boiling by turning off the gun, the flame goes out. So this dude is probably using plain alcohol which is ethanol, but I can't say for sure until I try it.  If you want to do this, do put some pieces of smashed ceramic in the tube to stop dangerous bumping. Might put video up if requested.
Don´t you think the moderator and the experts in the TV there watching it, wouldn´t have smelled the alcohol ?
Have you seen the other video, where he picks up a glas of saltwater from the Greek Sea and puts it in his newer cold ion MHD Reactor and out comes about 230 Watts of electrical power ?
https://youtu.be/twYbr-ZSU0g?t=12s
You really need to watch ALL the videos of his channel:
https://www.youtube.com/channel/UCa1TJGxtBLX2yK9uL9rwZoA/videos
I did watch this the last 2 weeks and he has several new OU inventions, especially his strange cold ion MHD type generator or special
Fuel cell is amazing ! 240 Watts (12 Volts x 20 Amps) from just water by using this GigaHz water splitting technolgy and then combining the
hydrogen and oxigen in his special cold ion MHD generator or special selfmade fuelcell, but without any graphite electrodes...
Regards, Stefan.
hartiberlin
hartiberlin
Here at Minute 9 you can see, that he is using a selfmade 12 Volt DC to 220 Volts AC Inverter
behind his "cold ion MHD Generator" to convert the 12 Volts DC to 220 Volts AC and power AC Loads, like the
lamps, Mixer and radio.
https://youtu.be/RDJh2j-Skds?t=8m53s
hartiberlin
Here he has in this video at about Minute 32 he shows even a more basic toy version:
https://youtu.be/RDJh2j-Skds?t=32m17s
He fills this box with water, which he tastes before and drinks a bit and then puts it into this small
box where he has probably 2 dissimilar metal electrodes, that probably generate a galvanic voltage.
This voltage is then used to power the 2 microwave circuit boards on each side of the box and these
then produce the hydrogen and oxygen that is fed to these 2 special fuelcells that he puts ontop the box and
they then generate more electrical power to power the 2 fan motors...
You see at minute 38:38 that these 2 circuits are pretty simple, just an RF transistor and a few right passive components...for the Ghz pulse generator...
https://youtu.be/RDJh2j-Skds?t=38m38s
So he needs very low power for these two Ghz RF PCB circuits but gets much more power out of his special fuel cell from the hydrogen and oxygen...
Regards, Stefan.
