Bike runs on water 100 % - No Gasoline - Microwave Pulse Generator Water Split
Started by hartiberlin, May 04, 2016, 02:29:43 AM
markdansie
Quote from: ramset on May 09, 2016, 09:15:33 AM
Yes
I have asked the Inventor and his representative {Lawyer] to address certain issues , mostly for a simple gas spectrometer test
to start with . [ which as mentioned prior,  is available quite easily in Greece's Auto emission's testing infrastructure .
It is not clear at this point where this will ultimately Go ? His Lawyer mentioned the next Month would be a time for decision making ?
Please keep all input here respectful , I did not get the feeling that the Inventor or his representative will shy away from Further testing and validation !
respectfully
Chet
I always find the most simple way to eliminate any doubt in the past is to do an emissions test on the scooter. Like the water powered bike on 60 minutes in NZ it was busted when they found hydrocarbons in the exhaust. I used the same method many times myself.
A gas spectrometer test would alos be very nice[/size]
Kind Regards
Mark
Turbo
Quote from: pomodoro on May 04, 2016, 12:08:24 PM
The flame is not hydrogen. The yellow is from carbon. Most likely methanol, which only has a small amount of carbon and burns just like that.  Metal is heated inductively and boils methanol at 65C leaving behing the water it was mixed with. It was mixed so it wouldn't burn. You can tell its boiling because the bubbles are huge. Electrolysis and gas evolution on metals give very fine bubbles - always.
This is correct observation
It takes from 40:15 to 41:21 to 'cook' the liquid.
If this was true 'palmolisis' it should start immediately,
massive
the 60 mins , Steve Ryans motor bike was not "busted" by a CO2 emission test
ALL vehicles that use oil in the engine will show CO2 in an emission test no matter what fuel is used
it doesnt matter if its 30/40 or sun flower oil .  Oil gets past the rings in ALL motors .
No hydrogen powered piston motor would pass a test with out showing CO2
No Hydrogen invention can make it to the market in an oil based economy OR an electric vehicle economy
Turbo
markdansie
Quote from: massive on May 11, 2016, 03:47:16 PM
Your right it was not the CO2 it was the hydrocarbons and yes an allowence is made for the combustion of the lubricating oils.
I have worked with over 6 emmissions testing
