Bike runs on water 100 % - No Gasoline - Microwave Pulse Generator Water Split
Started by hartiberlin, May 04, 2016, 02:29:43 AM
Acca
Thanks for the most "important" discovery S.H. as this may be the real deal RF and microwave tech are very mature industry and just that fact may get this method off the ground especially in Greece that is really in the major economic self destruction...
I am in RF design in microwaves since the 1980's and will be doing my best effort on this subject too.. I am Polish and have a stake in Europe as I hate diesel smoke and some 40 percent of cars in Europe belch out this smog.. Smog in Paris very bad it was this week...
Acca..
ps. posted some pics of the great Greek engineer..
Kator01
Acca,
good to know your experience in this electronic field. Electronics is one part another is the catalytic material he is using.
Without it - as I have understood - it does not work
Some time ago I noticed this post #1 from sm0ky2 here:
http://overunity.com/16497/3x-hydrogen-from-water-efficiency/msg478635/#msg478635
Links unfortunately are content-restricted and/or do not exist anymore. Strange...??
Mike
Acca
Mike here are some links for you are to your question .. these are very good pdf's
Enjoy.. Al aka Acca..
Here are the documents on this spitting of water from Michael Nunnerley
And YouTube clip on stainless 316 below ..
Uploaded on Feb 20, 2016This is one of the original tests of SMD, dating back from when I first started on creating hydrogen from water at a very cheap price.
The left electrode is a hydrogen only electrode, the middle electrode which changes colour (oxide), is the changeover electrode. The right electrode is the positive which produces little gas. All electrodes here are 316 stainless steel, the changeover electrode is being broken down at a very fast rate.
https://www.youtube.com/watch?v=5Pxm4eVDc2s
https://drive.google.com/file/d/0By3_AfqtEMFsYUI2MXB0Rk9fYmM/view
https://drive.google.com/file/d/0By3_AfqtEMFsNUhyT09MTGMxVXc/view
https://drive.google.com/file/d/0By3_AfqtEMFseHhiR0JxSmhxaTg/view
pomodoro
Quote from: Kator01 on December 09, 2016, 12:56:30 PM
Acca,
Mike
Those links had nothing related to the topic. It was a strange post.
Acca
 Here is  (Πέτρο Ζωγράφο) Greek  (Pétro  Zográfo) , or  Peter Painter in English..
His web posts ..and the written  post below..
http://www.hellagen.gr/
"COLD COMBUSTION REACTOR FOR PRODUCTION OF ELECTRICITY "
This is an innovation that converts chemical energy directly into electrical energy through two processes:
A) Through an electrochemical reaction, and
B) Through a space irradiating system, wherein said electrochemical reaction is carried
This particular type of reaction involves the transfer of electrons from one material to another through an external circuit.
This process can be continued until the circuit is interrupted or the supply of external irradiation, or even eliminated if one of the reactants components.
The hardware component that is replaced is usually the rise.
As the reaction in the electrochemical device is not subject to any restrictions or prohibitive provision of the Carnot cycle.
As a result, the cold combustion reactor has the highest energy conversion efficiency.
It is also known that the temperature and pressure within the tube cavity, wherein the reaction proceeds, plays an important role in the conductivity of the liquid solution.
This conductivity of the slurry should be as large as possible, which means a very low ohmic resistance between the electrodes.
The above, ie low resistance and high conductivity, not achieved with strong acids, as this would be disastrous for the environment.
In the system throughout evolution, electromagnetic radiation, which receives the liquid solution and which irradiation should be done at a specific frequency, has a key role in the process, as shown by the appropriate measurements and the effect of the degree of device yield.
In the fluid environment of the cavity tube, wherein the reaction occurs, are suspended metal particles in powder form to be greater absorption of electromagnetic radiation.
Out of these particles in the fluid environment of the cavity tube there are dispersions of colloidal silver in specific proportions, allowing in this way the flow of larger electrical currents.
Obviously, thereby circumvented and the prohibitive provision of the theorem of Carnot cycle, because with this method of direct conversion can easily achieve higher yields by 96%, ie much higher yields than current yields of nuclear reactors electricity.
Use diodes IMPATT XR2F, which can yield larger, up to multiples force of about 2,5 Watt at frequencies TERRAHERZ.
Acca..
I think he is here to save the World from pollution and More....!!!
[/font]
