0 Members and 142 Guests are viewing this topic.
yes it can
5 (25%)
no it cannot
11 (55%)
I have no idea
4 (20%)
Total Members Voted: 20
tinman
MHs question on the JT thread
QuoteWhat happens to the energy if you pump 100 watts of power into an ideal voltage source for 10 seconds
Poynt
Am i correct in saying-->as an ideal voltage source dose not dissipate any energy,the energy is contained in that ideal voltage source.
Brad
tinman
Quote from: webby1 on May 18, 2016, 09:46:07 AM
My assumption would be that since the Ideal Voltage Source has no means to dissipate nor store energy that the current flow would continue from the inductor through the Source, and at the time of the reversal of the polarity that the source would initiate a stream of charge carriers moving in the opposite direction.
Considering that at the time of a drop in voltage from the source the conductors self-inductance turns the conductor into a source, but not an ideal source, the 5h rating, it has a limit on stored energy and with no input from the source that energy would dissipate.
To hold against a change in current flow the self-inductance would need to be infinite but since it is not then the induced magnetic field would be less and resultant CEMF would be less.
So then,, at the moment the polarity is reversed from the source there would be no impedance to current flow from the source until the prior stored energy is dissipated.
And the value of that unimpeded current flow at this time would be?
Brad
tinman
When T=7s,would the below be correct?.\
Brad
minnie
   Try looking at "abstraction" in Wiki and then it might make more sense.
          John.
Reiyuki
tinman,
Seems there's just too many floating variables to nail down any of the 'weird' properties that show up at the extremes of an inductor.
In retrospect, you should have asked about an ideal capacitor, and the paradoxical properties of 'displacement current' ;D
