0 Members and 110 Guests are viewing this topic.
yes it can
5 (25%)
no it cannot
11 (55%)
I have no idea
4 (20%)
Total Members Voted: 20
verpies
verpies
How about the Root's Blower with flywheels attached to the impellers and voltage symbolized by the pressure difference between two air-tanks?
Quote from: webby1 on May 08, 2016, 09:13:07 AM
You should say, "Okay, I will discuss it with my peers and go do more research and learn more and improve my skills so that I can answer the question successfully by myself."
After all the ground that has been covered in this thread, and for the innumerable crazy theories and misconceptions that have been addressed and dealt with, don't you feel a bit ridiculous for trolling me like that on the very first page?
verpies
Quote from: webby1 on May 22, 2016, 10:46:39 AM
I have an issue with the pulses from that,,
Pulses are a minor imperfection that have no bearing on the overall energy balance.
The temperature difference due to air de/compression is a much larger flaw in this analogy.
poynt99
Since most of the technical discussion has already occurred, and other sims posted, here is my voltage and current trace in its complete form. R=1m Ohm.
Hopefully Brad will continue on the quest to discover the facts about this circuit, and perhaps use my proposed timing with his welding coil to prove it out on the bench. I would suggest that proving the entire wave form is not even necessary, as the main point hindering the understanding I believe has to do with the transition from a positive current to a negative source voltage. I am sure Brad could set up this single voltage transition on his bench without the need for an elaborate wave form.
