matter is there only 50% of the time
Started by buzneg, November 04, 2006, 01:51:55 PM
raburgeson
If you look at metal under a very powerful microscope you can see the molecules crawling around on the surface, so I believe you are maybe way more right than wrong. I discussed this earlier talking about magnets and crystals. Magnets and crystals have a special arraingment of atoms that have to return in a specific order and store energy that is normally released by atoms in other molecular structures. No matter where the other side of the Universe or a different dimension or who knows they return in the same order. This has ties to the Ether Theory, I bring your attention to This: Check out mini-whirlpools and consider vortexes from the paths of these traveling atoms. :The scientist of the period spoke of the Ether wetting matter. Try this , take a smooth board and set it just a hair off level, then wet your finger with water, (now without trying to overcome gravity) draw a crooked line on the board. Use a eyedropper to add water to your wet trail. The water will follow the wet path. Yes I know coehesion, adhesion and surface tension. These do not relate to mass traveling at or above the speed of light bonding to nothing during its movement in its path. I theoried material other than crystals and magnetic materials could allow the return of the atoms possibly upside down or at any given angle and they would be allowed to shift into place after returning. That could cause the molecule to move. It would be great if we could crack extracting crystal power wouldn't it.
allcanadian
Something existing then not existing would be a violation of the conservation of energy any way you look at it, I think this multi-verse theory is quackery so some people can make themselves look smart.
Have you heard the story of "the emperors new clothes", I think they apply here.
Kator01
Hello,
you may have a look at this which I found a few years ago :
Boisvert's Discovery of the Discontinuity of Motion
http://www.islandnet.com/~gds/Homepage.html#Discontinuity%20of%20Motion
Go to NEXT or Tbale of Contents
Hight-Speed-Pictures of very fast bullets show quantum Leap in the course of time; if there is not a basic mistake ( artefacts) in the system.
Kator
bbass
There is entropy only when energy is unbalanced. I Think the man is speaking of matter being here(1/2 spin forward |1/2 spin reverse), and then not. Generators produce electricity. There are no electrons in a magnet. In a generator, the stator (magnet) rotating inside the coil, brings them into existance. We must remember the Planc constant. There is a place where nothing exists. We all came from there. Everything still does. Creation hasn't stopped.
buzneg
For some reason I think when photons electrons are created it is a result of even much smaller particals in space that we thought was empty, because we used to think outerspace was empty and they we found dark matter and that makes space clouds that vortex into stars, why not go furthur then just dark matter and say there's even smaller things? The smallest things would have the most momentum aswell when they give it up they then fall into gravity, and form larger particals, mometum, and gravity act like counter weights. Though I'm not educated so I could be way off.
At least as far as DC motors go, I think its a gyroscopic effect made on the atoms by the magnetic fields that cause them to "pump"
