Ok...this is odd!! (shielding)
Started by Creedo, November 06, 2006, 11:59:59 AM
xingu
Hi Creedo,
This is very interesting. Could you also give some more specifics on the magnet itself?
regards
Xingu
pese
Hallo , das ist eine einfache Sache.  Diese starken Paperclipmagnete von ca 30mm  Durchmesser , enthalten auf der Vorderseite  3 Magnetsysteme mit je 2 Polen (N S) !!!  So gibt es 6 Magnetpole !!    Wenn Ihr nun mit einen  Metall Blech oder nur Paperclips diese Pole kurzschliesst  = Magnetjoch , so k?nnen keine Magnetfelder mehr nach aussen wirken .
Das ist das totale Geheimniss , wenn mann weiss das dieser Magnet NICHT N und S auf entgegengesetzten Fl?chen hat , wie das bei  anderen Magnetscheiben ?blich ist.    Teste dies mal aus mit einem Kompass oder  einem normalen Magnet , so findet Ihr die  Vielzahl der Magnetpole auf EINER Seite !
Pese
Google (revised translation):
Hello, that is a simple thing. These strong PAPER tie-clip magnets of approx. 30mm diameter, contain 3 magnetic systems with 2 each Pole (N S) on the front!!! Thus there are 6 magnetic poles!! If you short circuit now with metal sheet metal or only PAPER tie-clip these poles = magnetic yoke, then no more magnetic fields can work outward.
That is the total secret , if man does NOT know this magnet N and S on opposite surfaces has, how is usual with other magnet disks. , Then you find the multiplicity of the magnetic poles on a side to test this times out with a compass or a normal magnet!
Pese
This way it is to understand , that all 3 magnetfields (at one side) will be shortet by paperclips .
Creedo
Quote from: xingu on November 06, 2006, 03:16:17 PM
Hi Creedo,
regards
Xingu
The magnet itself is basicly a 1-1/2" diameter wafer and about 3/8" thick with a 1" diameter hole. The magnet looks to be iron ferite.... not sure. Its black and looks as if it has a few tiny chips in it. It has some decent strength for its size. And it actually came from a paperclip container. I use it mainly to hold paperwork to the side of my metal cabinets at my office.
Creedo
Got home late last night, will post pics tonite! Sorry for delay...
Dingus Mungus
You may want to also test to see if multible poles are exiting on the face of the ring magnet.
just my 2cents...
