Reviewing Pulse Motor Circuit Ideas and Theory
Started by earthbound0729, May 29, 2016, 10:49:22 AM
tinman
 author=earthbound0729 link=topic=16645.msg485620#msg485620 date=1464911160]
Thanks everyone for this interesting interlude in life. Hope it leads to useful data for all.
earthbound
QuoteI have been reading some info regarding the SSTC in general, and seeing many videos, especially in regards to my wanting to experiment with high frequency pulsing in the air coil to achieve improved Radiant Energy collection without a rotor.
To what !radiant! energy are you referring to?
Brad
earthbound0729
Hello Brad,
My initial starting point with the use of the word "Radiant Energy" is with the collection of energy as described by Bedini which is collected and channeled to either capacitors or through a bridge rectifier to the "charge" battery.
As I read more about Tesla and what he was working with in the early 1900's he used the term aetheric (Radiant) energy to describe something which seems to be similar to a point, but not actually needing the same circuitry to accomplish its end goals, although needing that circuitry to initiate the process of the aetheric generation from a high dc voltage generation point (other than atmospheric energy).
I think any illumination (definition)on the terms used is most beneficial Brad, and must be the start point, so my context can be accurate and everyone is along the same lines. I welcome any input you have. Also too, better to get the definitions down early so the correct path is chosen.
TY for the query.
earthbound
ltseung888
http://overunity.com/15077/ufo-propu-engine-closed-loop/msg485521/#msg4n
Use DSO to examine the negative energy waveform.  It is what I refer to as the lead-out energy...
That is an important tool in helping to develop the Fung Wheel or the lead-out energy flying saucer.
earthbound0729
hello ltseung888,
I looked at several of these videos via the link provided which in turn linked to others. As noted by one of the  viewers, manual control of the pulse is poor at best and humans don't focus that well on the timing, but the automatically sensed trigger of at least a bifilar coil arrangement as Bedini included in his designs is good, or using a hall effect sensor arrangement. I didn't really understand what the point was in the videos you supplied, which seemed to be going over old ground. Maybe I missed something.
earthbound
tinman
Quote from: earthbound0729 on June 03, 2016, 05:08:12 PM
Hello Brad,
TY for the query.
earthbound
Ok,well i guess it comes down to whether you want to work with the truth,or follow the Bedini brotherhood?.
The brotherhood would have you believe that the bedini circuits pull in radiant energy,but the truth is,the bedini circuits actually emit radiant energy-they do not pull it in.
This radiant energy is in the form of electromagnetic energy,that is emitted from the inductor/coil of the bedini circuit's. Some of this radiant energy is also emitted as heat,by way of resistive heating. Anything that has resistance,and where a current flows through that resistance,heat is emitted-or radiated away from the circuit,and dissipates into the surrounding air.
The biggest problem here,and why some believe that the bedini circuits produce some sort of !overunity! effect,is due to the lack of understanding between surface charge,and deep charge of lead acid batteries.
The second !trick! that you see on bedini's forum's,that is in some way suppose to prove more P/out than P/in,is what they call the !1 ohm !test. But what they do not understand,is the current loop that exist within the circuit,and it is in this current loop where they place there 1 ohm resistor to try and show more power out than in.
Todays !off the shelf! boost converters are far more efficient than the bedini circuit's,and a lot of battery chargers these day's come out with a desulphator function.
But it's like i said--you can choose the bedini way,or you can choose the truth-->it's up to you.
Brad
