Reviewing Pulse Motor Circuit Ideas and Theory
Started by earthbound0729, May 29, 2016, 10:49:22 AM
earthbound0729
I have seen several of your vids dealing with the PLL SSTC, plus oscillators.
I have also seen that PLL and VCOs are available to include in the circuit types I need to consider in my quest. I saw a VCO by Texas Instruments, the SN74LS624N which can handle 1.1- 25 MHz.
I also see that MileHigh has 2 comparator circuits I found. One appears to be simpler, while the other is marked as ver. 3.0 from Oct 11, 2013.
There are still sensing coils seen on these circuits, while what I envision wouldn't need the trigger coil, it would only need to energize the NPN transistor or other switch type which can handle the frequency of the oscillator circuit.
Your PLL circuit and the oscillation circuit appear to based on an entirely different design than Mh's comparator. Am I seeing that correctly ,sir? And is this because you are using this with Tesla coils and need the higher frequency generation?
You also mentioned having the resonant circuit built in with your PLL in one of your designs and that when tuned would create the needed resonance. From what
I've read in dealing with frequency this formula must be used:
http://www.1728.org/resfreq.htm
to calculate those important values. And I will be assuming certain knowns here.
Thank you for your time in helping to untangle these threads TinselKoala.
earthbound
dieter
Yeah right,  tinsel and mh are the perfect sources for information about free energy, as they believe in it soo much.
Or do you just wanna recondition your sulpated lead batteries?
Even if you think I'm wrong or stupid, I consider it rude to ignore my answer to your question so explicitly.
earthbound0729
Quote from: dieter on May 31, 2016, 07:20:52 AM
dieter,
Let me start off by apologizing to you. It was a selfish oversight on my part and not intended to cause pain. I do know how it feels to either be misunderstood or ignored on forums, but I assure you, my oversight was not intended to slight you in any way. I don't know you, nor would I publicly defame you. I seek the best out of our forum and wish for all of us to treat each other respectfully here, so I appreciate you calling me out on this. Please forgive me and I wish to be on better terms with you.
Also, your insights were not ignored by me, but appreciated.
TY,
earthbound
dieter
no problem. I seem to be a bit touchy today and may have overreacted / missinterpreted it.
earthbound0729
I have been reading some info regarding the SSTC in general, and seeing many videos, especially in regards to my wanting to experiment with high frequency pulsing in the air coil to achieve improved Radiant Energy collection without a rotor.
Many questions come to mind.
1. Why use smaller gauge wire in my Tesla air coil? It does not seem to be addressed in the computational algorithms for calculating frequency. Of course, maybe that is the point.
2. This seems like it would increase resistance significantly. Is that needed or desireable?
3. Also it seems like smaller diameter coils see the highest frequencies potentially. I would also assume using the smaller gauge wire as well.
4. Most of what I see as evidence of a well made SSTC is the streamers, sparks or corona mentioned several times without causing undue heating in the circuit, esp. the mosfets. That is not what I am needing this for, although it does look cool. I need beyond cool.
5. Am I going to be pulling the Radiant energy from the coil in the same way as the Bedini method, by connecting to the coil ends? This is especially important since the SSTC has both a primary and a secondary winding. Which to use?
Many more question of course, but later. Haven't even really touched on the circuit design and power needs.
Thanks everyone for this interesting interlude in life. Hope it leads to useful data for all.
earthbound
