H2 to 2H - what are the options?
Started by dieter, June 04, 2016, 04:11:31 PM
dieter
Thanks, that's interesting, but the vid doesn't give much info, just some lab footage.
I do wonder about the neccessary amplitude or decibels, and whether there is a linear input / output ratio.
Uncoupling the methods of splitting and combusting (like: in sound, out heat) would certainly be promising, in terms of potential nonlinearity.
Also, 40kHz, even a simple, cheap joule thief could do that, just add a piezospeaker to it and sweep trough R1...
ourbobby
Quote from: dieter on June 13, 2016, 06:16:21 PM
This is all very nice and good, and yet I get the impression that I am the guinea pig in this experiment ... nah, just kiddin' ^^
I get the impression we are all of us the guinea pigs. It flits from one position to another.
Anyway, from your initial posting. Are you familiar with Randall Mills' work? Although it would seem after the years he is been at this that the opportunities are by way of investor funding! The catalyst I believe is associated with Potassium which he collects and recycles through the system.
http://brilliantlightpower.com/
Have a good day
dieter
Thank you, the same to you!
Randall Mills, rings a bell kind of...
Pity my browser cannot handle that page. I was just reading about Hydrinos, when most of the page vanished.
Anyhow, it didn't seem very open-sourced, considering the various "registrated trademark" symbols, but maybe I am missing  the point.
ourbobby
Quote from: dieter on June 13, 2016, 10:24:46 PM
Hello,
         I was pointing to the development of those technologies that you expressed in the start of the thread: the exception being the conversion of energy using solar cells; originally proposed back in the 1930's through the use of silicon for the facilitation of "lightning" reproduction . Also, I get the impression that Dr Randall Mills is using his selective demonstrations solely for the purpose of fund raising, which has been going on for some time.
SunCell® Generator System Design, Operation, and Hardware
The SunCell® comprises five fundamental low-maintenance systems, some having no moving parts and capable of operating for a decade or more: (i) a start-up inductively coupled heater to first melt silver or silver-copper alloy and optionally an electrode electromagnetic pump to initially direct the ignition plasma stream; (ii) an injection system comprising an electromagnetic pump to inject molten silver or molten silver-copper alloy and a gas injector to inject water vapor and optionally hydrogen gas; (iii) an ignition system to produce a low-voltage, high current flow across a pair of electrodes into which the molten metal and gases are injected to form a brilliant light-emitting plasma; (iv) a light to electricity converter comprising so-called concentrator photovoltaic cells that operate at a light intensity of over one thousand Suns; and (v) a fuel recovery and a thermal management system that causes the molten metal to return to the injection system following ignition.
The Power of the SunCell®
The SunCell® plasma-producing cell invented to harness this fundamentally new primary energy source as electrical output uses a catalyst to cause hydrogen atoms of water molecules to transition to the lower-energy Hydrino® states by allowing their electrons to fall to smaller radii around the nucleus. This results in a release of energy, that is intermediate between chemical and nuclear energies, and a nonpolluting product. The energy release of H2O fuel that can be acquired even from the humidity in the air is one hundred times that of an equivalent amount of high-octane gasoline.
I think that this is an area Franco was interested in. Using HV to extract N H O from the atmosphere, which in fact creates a resolution of unstable atmospheric conditions and a massive energy flow! . I have a good book called "Ball Lightning and Bead Lightning" J D Barry, that documents the history of investigations into lightning production. Worth reading.
However, importantly, his work is a step forward and in the marketplace.
Thanks
franco malgarini
There is also the electrolysis with lead amalgam catode, very simple:
