Gravity assisted power project- GRAM
Started by burnit0017, June 11, 2016, 05:07:37 AM
burnit0017
https://youtu.be/4Oj5fGAKXaE
Hi, I found the above human powered device on youtube. I am attempting to replace manual operation with a automated pendulum to tilt the table.
Short videos of the project.
https://youtu.be/sQqq6srUljU
https://youtu.be/mVWJ5Dnr8-c
https://youtu.be/iJujIiis5lg
https://youtu.be/Dl7goWuaEyc
conradelektro
What will be your power source? (Ocean waves?)
In other words, what will drive the pendulum?
Greetings, Conrad
burnit0017
https://docs.google.com/drawings/d/1jERgsxrV1yPyaIp4kEyS_R9s-T8iaWpnTcQ2DBFkHyw/edit?usp=sharing
Hi, One stator of a the PMA will be used to charge a cap that will drive the electromagnets in repulsion mode. The real power source is gravity.
It sounds like a word game but it is not. Once the device is started, it is stuck in a continues loop. I should be testing in a few days.  Good or bad, I will post results. Thanks for showing interest.   No water required.
ramset
burnit0017
yes your vids do a good job of explaining you direction , a bold one it is.
harvesting energy from the gravity field .
intriguing concept , I noticed a little yellow and orange Teaser in you intro and now above a more detailed Pic .
what part does that play or is it another project, sorry if I missed that?
thanks for sharing your interesting build.
respectfully
Chet
Thanks Grandma
burnit0017
Hi, it is a multi stator permanent magnet alternator. I intentionally made the stators with a high internal resistance. It will produce a high voltage at low RPM. I will use a DC to DC step down converter  with a variable duty cycle to reduce (I squared R) loss at the stator. The only claim at this time is it not a overunity device. The configuration is easy to fabricate, so others may do their own testing. Cheers
