Gravity assisted power project- GRAM
Started by burnit0017, June 11, 2016, 05:07:37 AM
Mem
Quote from: burnit0017 on May 22, 2017, 01:20:37 PM
https://youtu.be/G_jt9YJnG5M
Reduced e-mag core end has improved RPM
Couple of ideas that may help to fine tune the system and  give you more power on electromagnet.
1-you may want use magnetic rid switch to control the electromagnet via mosfet or a power transistor which will allow you to fine tune and get maximum propulsion power out of electromagnet. Similar to pulse dc motor operation.
2- Put your electromagnet into metal tube/pipe and close the back of the tube/pipe as well like round washer or metal plate, by doing so you will increase power of your electromagnet may times. Or else you lose most of the electromagnet force if you don't enclose the coil in a metal housing.  For example: Transformer would not operate without a metal core.
Mem.
burnit0017
Hi, thanks for taking the time to post the suggestion.  I used that configuration on the first pulse motor I made. basic testing showed me that I can get better results using the GAP power or mostly permanent magnet motor configurations.  Thanks again
burnit0017
Mem
Quote from: burnit0017 on June 11, 2017, 12:41:50 PM
https://youtu.be/5EcuuFbSwSg
dual coil, looks easier to fabricate
Looking some of your videos it's quite impressive to see  amount of time and labor + $'s that you have invested in this R&D.
More power to you man!
I sure do lot's R&D in Hawaii but it's the fraction of what you do. Having a like minded buddy/friend definitely helps to discuss  these ideas.
Some day I hope to tackle this project. https://www.youtube.com/watch?v=3DKUFoWAuj0  the principle of modification of the generator is here in this drawing. I have no idea who make the drawing, but looks very good.
burnit0017
https://youtu.be/UlGjr2VBxR0
linear pulse motor fabricated, please watch safety videos
