Thanks to ALL for your help!!
Gravity assisted power project- GRAM
Started by burnit0017, June 11, 2016, 05:07:37 AM
Low-Q
All I can say is that you have a strong will, burnit0017 :-)
Aside from that, and not to be a party killer, but I might have experienced from several experiments that gravity and magnets can't provide energy...
If you really want to try something, that I failed in making, is this one:
https://youtu.be/LDRorMyxdO0
If you for some reason can make a magnet that keeps its magnetic orientation while it is spinning around, this device will actually work.
The idea is that the inner rotor is a magnetic south pole at the circumference, and north pole in the center. The outer rotor is magnetized through its diameter so south is on one side and north on the other side - even if it is spinning around.
IF you can achieve this, you have a magnet motor with 20% excess energy.
Let me explain:
In this construction, both outer and inner rotor has the same torque, but the inner rotor spins 20% faster than the outer rotor due to the 5/4 gear ratio. This is proven by simulations only. That means the energy of the inner rotor must be higher. As you know that torque multiplied with RPM is energy.
The problem:
How can I get a permanent magnet keep its magnetic orientation in the same direction while it is spinning? When that problem is solved, you got yourself an over unity device.
You cannot magnetize the outer rotor with external magnets. That will cause the outer rotor to increase the torque to 20% more than the inner rotor. So it will not work.
Now you can start figure things out to make it work :-)
Low-Q
Quote from: burnit0017 on August 31, 2016, 02:16:09 PM
https://youtu.be/8RKKecCTds4
I must say you really put lots of good work into your projects. I'm impressed. Hope it works as you want it to :-)
burnit0017
https://youtu.be/I0MdmaIZrkU
posting just for info, nice pendulum configuration, I will give it a try
