Gravity assisted power project- GRAM
Started by burnit0017, June 11, 2016, 05:07:37 AM
conradelektro
Quote from: webby1 on September 19, 2016, 11:04:40 AM
Here is a simple method I use to take an oscillating input and convert it into a single direction rotating output.
In 700 if you look at the top left part of the picture you see the input arm connected to the first input shaft,, then to the right of that first input shaft\gear\one way bearing is the second input shaft with its own gear\one way bearing and then to the right of that is the output shaft with its own gear\one way bearing.
In this setup I am using levers to connect the two input shafts,, but sprockets and chain work as well so that you are not limited on the angle of rotation per input cycle.
I used a one way bearing on the output so that the output flywheel would keep spinning without  the input system moving,, in other words if the input slowed down it did not slow the output down with it.
I like that setup, specially because the fly wheel can run away.
May be one should mention that the ratchet bearing (or one way bearing) in the middle should block in the opposite direction in comparison to the the first and third ratchet bearing.
Greetings, Conrad
burnit0017
https://youtu.be/rtcsLgCZybo
it looks like I have to rework my pendulums, I have the chain drive on the wrong pendulum
burnit0017
