24/365 solar cell output theory and experiments
Started by lancaIV, June 23, 2016, 07:30:16 AM
Reiyuki
Quote from: Dave45 on June 24, 2016, 07:52:07 PM
Interesting, late night project.
I wonder if it's the magnetic field or the flux that enhances the effect?  Maybe it needs to be an electromagnet or vibrating neo?  It would also be neat to try running the solar panel output in series with a low R electromagnet so it's a continuous feedback loop.
http://www.google.com/patents/US5009243
but without detailed Keelynet info like :
(You should obtain the entire patent and study it.)
Our friend Wesley at Energy Research says, '[/size][size=78%]The output of this one is hard to believe. It has been witnessed by thousands of people. The output of one module that uses fewer cells than a conventional panel will produce between forty and seventy amps at 19 volts.'[/size]
publicated "only" from 0,5V to 1,0V magnification
Notwithstanding the formidable prior art, there is no teaching which shows or renders obvious the present invention solar harness which [/font][/size]utilizes magnets in alternating series with solar cells to create a conductive magnetic field to simultaneously support the solar cells in a solderless fashion and to enhance the influx of energy to the solar cells to create a high voltage series of cells. Further, many of the other features of the present invention described herein are not suggested or taught in the prior art.[/font][/size]
it has been found that substantial increases in output without substantial increases in surface area has been achieved by the arrangement of magnets and solar cells as used in the solar harness of the present invention. It seems that the magnets act to draw in photons so that more photons are striking the solar cell surface and being absorbed. Additionally, in a given stack, the magnets may accelerate the movement of photons and those that are not absorbed in the first solar cell of a stack may be pulled toward each of the next sequential solar cells in a stack until absorbed. This phenomenon decreases the random deflection of unabsorbed photons and therefore substantially increases solar cell photon absorption and ultimate electrical production. Additionally, the magnets themselves are preferably wrapped or wound with a conductive material such as a conductive foil, or a conductive wire or a conductive coating of highly conductive metals such as nickel, copper, silver, gold or the like. The windings or wrappings of conductive material may be the same for a series of magnets, may involve opposite windings on each magnet and/or variable windings, depending upon desired voltage and amperage. In one preferred embodiment, there are two (opposite) windings on each magnet and all magnets (except those end magnets with leads) are identical.[/font][/size]
The highly conductive magnets such as the aforementioned wrapped magnets may actually be performing four different functions: (1) the movement of photons towards a given solar cell surface; (2) the bending of electrons which might otherwise miss a solar cell surface towards the actual solar cell itself; (3) the movement of unabsorbed photons passing through a given solar cell towards the surface of the next adjacent solar cell; (4) the conduction of current down the stack of solar cells so as to increase electrical output in series. Of course, additionally, the magnets perform the very important mechanical functions of holding the solar cells in a given arrangement and of allowing solar cells to be added, removed, or substituted in a given array.[/font][/size]
In addition to the solar harness of the present invention, it has been discovered that the solar harness, when placed in an evacuated container, will experience further increased efficiency and increased output. Thus, the present invention solar harness may include a container which is transmissive to sunlight and this may be partially or completely made of glass, quartz or similar material. Additionally, it may be partially or nearly completely evacuated or the air may be replaced with a more useful gas such as inert gases like neon or such as other gases which are easily ionizable. It is believed that the substitution of air with these kinds of gases or the removal of a substantial number of air molecules allows for more photons to arrive at the solar cell surfaces.[/font][/size]
In addition, the solar harness may be located at the focal point of a paraboloidal reflector so that concentrated solar energy may be absorbed by the solar harness. Further, it has been discovered that, as a result of the particular geometry of a parabolic reflector and the fact that a glass or plastic or other coating is involved in the mirror of such a device, that the specific refractive index of the material of which the deflector is constructed will cause a prismatic break up of various wavelengths of sunlight and may place the very hot, red color light waves at a focal point different from the focal point where the blue, the green or the violet light might be found. As a result, it has been discovered that a solar harness of the present invention, when located at the focal point corresponding to the very hot, red color concentrated sunlight may burn up but, when placed at the focal point or points of the cooler wavelengths, will generate substantial electric current without suffering from extreme heat.[/font][/size]
ramset
A video !!
quite amazing how resourceful some members are here.
https://www.youtube.com/watch?v=n9dZm4njHP8
@ rensseak
thanks
@Lanca
I'll keep at it ,much more useful info there
[still not enuff ,however we should be able to reach a family member so as to Help Owen release this Technology
as well as understand it !! :)
Thanks
ChetKremens@gmail.com
Thanks Grandma
