24/365 solar cell output theory and experiments
Started by lancaIV, June 23, 2016, 07:30:16 AM
ramset
Lanca  Heard from  member Brad who is using the Sun for growing sprouts
I believe yield is 50 lb bag of black oil sunflower seed makes 5-600 lbs food in one weeks time.
can I beg your research skills here [MANY health claims] maybe a new topic ??
I will be "building" too [all supplies in pic below [ph meter 5.8 -6.3 ..?? for germination treatment/soak of sunflower seed
if not thats fine too [ i will start a topic soon
Thx Chet K  PS good hygiene important at all stages for healthy crop
Thanks Grandma
From enerergy exploration with high aerosol emission to solar radiation conversion up to nonstop :
https://www.wj-rottal-inn.de/images/2010/desertecvortrag.pdf page 7-
shows the beginning from the conversion project from decentralized production to E.U.-building program application " in situ solar radiation conversion",
consumer-centralized and portable .
alibaba.com solar panels turkey : under 20 Eurocents/Wp
2025 we can assume 15 Euro-cents/Wp and 2030 10 Euro-cents/Wp
NovaSolix calculates with at the beginning 20 Euro-cents/US$-cents down to 10 cents/Wp
From 5-3Euros/US$/Wp on tect installation to 0,5/0,3 Euros/US$/Wp -inhouse solar- installation costs !
3600 Wp and 10800 Euros actual market to less than 1200 Euros 3600 Wp inhouse.included inverter !
Because 3,6 KWp,divided in 18 sqm solar panel area, 1400 KWh/sqm  sun radiation value per annum and 15% solarelectric conversion = 210 KWh per sqm/annum ,this totals by 90% inverter conversion efficiency 3400 KWh useable power :
less expensive alternative if not Wp but "total power per year" economical orientation :
A.Ed Thorpe wind concentrator turbine + Arestov double winding + generator coil coating + inverter ~ 750-625 Euros for 3400 KWh per annum
           = uncontrolled wind farming
B. Fanerator,similar investment range,advantage related wind concentrator turbine : start/stop- on demand !
           = controlled wind farming
Psst Lanca
https://zpower.com/ Day and Nightime solar harvesting ?
you have a topic on this ??
I heard today this is real [well I did read sometime back too [maybe you ?
this one maybe we need some ?"research for experiments ??" [hows it work ....?
This man Reed has been a long time making the claim...
respectfully
Chet KEDIT
PS Hmm Now I remember we had this recently somewhere here ...his special "plates" .
https://www.youtube.com/watch?v=MsJwRznsf4o
https://www.pr.com/press-release/803895
To summarize ZPower's new solar technology:
- Clean power from the sun (no fuel consumption or toxic emissions)
- Constant electricity produced (24-7 non-stop energy)
- Affordable electricity (wholesale rates less than 2ยข per kWh)
- Solid-State (no moving parts with a projected life of 30 years)
- Compact Size (ZPower 1 Megawatt Power Plant needs 2.5% of 1 acre. But 1 Megawatt of solar panels require 2.5 acres)
  So by 8766 hours per year x 30 years and 10% capital tax and 2 cents/KWh we can expect :
                        1.250.000 US$/MW container-box investment ( = 1250$/KW)
Chet,probably 1 MW for "crowd funding"-groups for local "Energy Parc"-installation interestant !
6000 W zpower device : https://www.youtube.com/watch?v=2RBPGlW8hXQ  https://www.youtube.com/watch?v=6Re2HSMpC0U
https://www.youtube.com/watch?v=_-RsZDU4H7A
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fgehtanders.de%2Fder-fluxgenerator-von-james-b-schwartz%2F
This version already had 6000 watts of output power.
In a video he explains the following:
"Here we have three plates with a solid aluminum layer on one side, followed by a layer of bismuth , then another layer of aluminum with six recesses. The windings are attached there, followed by a layer of bismuth, another plate with windings, then another layer of bismuth, then another plate of aluminum, and so you get a panel.
http://fluxpowertechnology.com/   https://spark.adobe.com/page/sRdP4qaNoCRW0/
