24/365 solar cell output theory and experiments
Started by lancaIV, June 23, 2016, 07:30:16 AM
ricardotore,hello !
There is also beside A-B-,C-,D-,E-grade solar cells offer the possibility from surplus market auctions and second hand ware !
When you go net-wide  to aliexpress/alibaba and other gross-selling b2business  or direct selling b2consumer trade-platforms
the first detailed idea about Wp-quantity in knowing
there you get a first financial investment budget need aspect,
to include transport costs ,VAT ( which is international different) !
Between 5US$ per Wp( installed,ready to use)  and 0,20US$/Wp(solar cell module without inverter et cet.) fob
factory is a great price performance/amplitude today !
Up to 25x times KWh -final price difference !
Your wish - your search -your find-  your choice
Caution : commercial sharks
Sincerely
Heinrich Helmholtz    Karl Ferdinand Braun     Nils Bohr:Magneton-Modell
         Thermo-Cryo Dynamische(weniger,/mehr) Kreislauf,EE : LCR
Solar dots (ink)
Solar cells
Solar circuits
Solar closed cycles
Solar generator
Photo-voltaic cells ,Einstein
Phono-voltaic cells,Planck
Parametric cells,Braun
Resonant parametric cells,Braun
Resonant parametric generator,Braun,Magnetic field Transistor
All Das das gleiche Objekt benennend :
Bandweiten (' bandgap') Antenna-Receiver(Receptor,Tuner,Amplifier,Emissor),rectenna oder nantenna
                                          im Deutschen: aktiver Verstaerker
periodisch oder permanent die Resonator Operation,dazu Laplacesche 'Operator'(selbstausrichtender Tracker)
EMW-oder EMS  angular momentum (allgemein:Feldkraft) 4d XYZ Orientierungs(Fleming:links-orthogonal drehend,Lenz:rechts-orthogonal drehend)-Rechts-System- Wandler-Ring-Netzwerk
  Geometrische,hier Trigonometrie, Perspektive: Nullpunkt Wandler,ZP
Natural or artificial  'Solar'(=EMW oder EMS ) Transceiver
EMS + EMW : quantenmechanische Dualitaet,Licht-Welle,Quantenwirkung/-Zahl von Licht-bzw. Wellen-quant, ure
        ure ~ Weizsaecker-ische Ur-Kraft-Einheiten
1x 'solar nano dot' :
die kleinstmoeglichte ART der PLASMA-FUSIONS-RE-/AKTOR-BAU-WEISE,
AT-/TRAKTOR-Technologie
               ARTIFICIAL 'SOL' ( process )
2020 : 0,2€/Wp up
2025 : 0,15 €/Wp up
2030 : 0,10 €/Wp up
Adeus
OCWL
p.s.: Diese sehen den Wald vor lauter Baeumen nicht ,They can not see the forest for the trees
            venetian 'blind' ? Maske oder Maskara ?
Es gibt a. 'Tote',  b. 'Un-Tote' , c.  Lebende,wirkende : overunity.com : 83908 a,b,c ?
Since 1984 https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=19860304&CC=US&NR=4574161A&KC=A#
we have had to wait for 1 Euro- or Dolar- cent per Watt-peak solar cells production costs like here predicted :
https://www.chemistryworld.com/news/solar-cells-perovskite-films-made-at-record-low-cost-and-speed/4012887.article#/
25 $cents per square-foot solar cell area by up to 18% conversion efficiency
Amplifying the radiation per sqcm cell area : https://www.youtube.com/watch?v=l1QZAax0-XA
Hyperstealth's patent pending Solar Panel Amplifier has been demonstrated to more than triple thin film solar panel output and nearly triple the common monocrystalline solar panels.
AlienGrey
Quote from: lancaIV on March 06, 2021, 07:55:56 AM
Yeah! BUT a solar panel inst really a light converter it converts solar RADIATION into electricity.
How shall I understand your statement,AlienGrey ?
Is the Alvin Marks technology
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931207&CC=US&NR=5268258A&KC=A#
The manufacturing equipment, chemistry and processes for manufacturing these sheet products are described. The sheet products may be employed as a light-electric power converter (LEPCON TM ); or, in reverse with electric power supplied, as a large area laser, (ELCON TM ) used for 2D or 3D displays, for a high density high speed computer matrix and for a variety of uses.
,now used reversible :
artificial or solar light/radiation in  -electric out
to reversible :  electric in - solar or artificial light/radiation out ?
