24/365 solar cell output theory and experiments
Started by lancaIV, June 23, 2016, 07:30:16 AM
I worked over decades with a solar cell energy sourced calculator .
In -room ambiental light condition
https://www.intelligentliving.co/indoor-solar-cells-generate-electricity-from-home-lighting/
lux and lumen
https://translate.google.com/translate?sl=de&tl=en&u=https://www.ledpanelgrosshandel.de/Was-ist-der-Unterschied-zwischen-Lumen-und-Lux
Lumen - unit for luminous flux
The luminous flux ( also: light output ) of a light source is measured in lumens and provides information about the brightness of a lamp by measuring how much light a light source emits from all sides. The higher the lumen value, the more light the lamp emits.
The usual luminous fluxes in large indoor areas are 1100, 2000 and 3000 lumens. The required lumen output always depends on the height at which the lighting is hung (the higher the ceiling, the more lumens required) as well as the required range of the lamp and the appearance of the luminaire.
In order to determine the efficiency of a lamp, the wattage of a lamp is used in addition to the number of lumens. This is how you measure how much energy is converted into luminous flux. This measured variable is luminous efficacy and is measured in lumens / watt.
this  "lux and lumen" description above has not one defined important physical phenomen :
http://www.ransensoftware.com/Photometric/Answers.htm
https://www.pinterest.com/pin/535365474444137624/
       Lighting   f.e. ever 700lm and the Lux : distance - in cm - dependence
https://www.pinterest.com/pin/255438610094428839/?d=t&mt=signup
Hoeveel LED-lampen moet ik hebben?
             we read :  LIGHT SOURCE                  INVERSE SQUARE LAW
from #31 :
http://www.greenbusinesslight.com/resources/lighting-lux-lumens-watts
a measurement of 1 lux is equal to the illumination of a surface one metre away from a single candle.
Lux : definition by 1 mtr. distance ,1/10 -1/100 distance effect ? linear/progressive?         lux/lumen relationship
1 mtr fluorescent lamp :
solar cell arrangement ? sqcm aerea? market product efficiency 1985 ?
old 35 W lamps are today newer 20 W lamps light-emitting equivalent                  lumen/Watt  Lux/Watt  by  ? distance in cm
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3817730&OPS=ops.epo.org/3.1&SRCLANG=de&TRGLANG=en
In the article, they describe two variants of an organic solar cell where one variant has an area of 1 cm² and the other 4 cm².[/font][/size]
The smaller solar cell that was exposed to ambient light at an intensity of 1000 lux was able to convert as much as 26.1% of the energy of the light into electricity. It managed to deliver a voltage above 1V for more than 1000 hours in ambient light that varied between 200 and 1000 lux.
The larger solar cell was not as strong but still good, maintaining an energy efficiency of 23%.
Such semi-translucent photo-/phono-voltaic foils light devices ( fluorescent lamps  or compact-fl ) wrapping
or direct in factory : light emissive appliance and semi-transparent light-to-electricity coating
seychelles
LANCA ONE NEEDS TO KNOW WHAT TYPE OF ELECTROMAGNETIC WAVE HIT THE GROUND SURFACE 24/365.
THEN SHOULD CONCENTRATE ON THAT TO CAPTURE THAT SOURCE OF ENERGY.
The earth,as capacitor/condenser-condensator, has several different em spectrum particle/corpusceln and  wave to receive/store/emitt
the earth = receiver (EE-view)
Why making it more complicated  ::)
today the wished wave-length is "designed" by reflection/refraction and filtered/concentrated also making invisible
https://www.hyperstealth.com/
seychelles
BECAUSE THE SOLAR PANELS CAN NOT CAPTURE THE SUN AT NIGHT, SO WE HAVE TO LOOK AT
PICO METRE WAVELENGTH GAMA RAYS AND X-RAY. 24/365 REMEMBER.
Quote from: seychelles on May 29, 2021, 09:02:39 AM
Forget the expression "solar" and use photon and phonon ! photo(n)-voltaic and phonon-voltaic also called phonon=thermal
        voltaic = noise  ( signal-to-noise,never heared ?)
24/365 light device on = 24/365 light emission + light-to-electricity conversion
https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/Photoelektrischer_Effekt
in winter = 1 season of four 24/(365/4) light on = anti winter-depression ;)  (light therapy )
https://www.mayoclinic.org/tests-procedures/light-therapy/about/pac-20384604#:~:text=Light%20therapy%20is%20a%20way,called%20a%20light%20therapy%20box.
8)  If You are feeling Yourself "bad" probably caused "SAD" ;D   seasonal affective disorder (SAD)
Lamp source : water-carbon cell or Nano-Boxx or self-sourcing by
=   per         charge cycle     0,0002 USD or   0,02 cent
  https://www.greencarcongress.com/2020/02/20200220-attia.html
                                    Are we soon here ?
       =   per          charge cycle     0,0001 USD or   0,01 cent
                                   capacitor/batteries feed-back circuit
we have this feed-back circuit in cars ,by light-machine/battery = conventional
we have capacitor and batteries commercial
we have photo-/phono-voltaic cells/generators
we have many different light emitting lamp types
Only more the question how cheap to bring this all together and to be individual local /global in the "plug & use" stage !
And without concentrated fabrication ,each county in countries their all needing parts self producing !
We can calculate with up to 9 KW per sqm/m3 output
based by
Paul Heinrich Marzahn ~ Koehler + Mirror: light intensity amplication
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=heinrich+marzahn&IN=&CPC=&IC=&Submit=Search
solar cell output enhancer:http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=U1&LOCALE=en_EP&NUMBER=29520064&OPS=ops.epo.org/3.1&SRCLANG=de&TRGLANG=en
lamp consume saver:
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=U1&LOCALE=en_EP&NUMBER=29703156&OPS=ops.epo.org/3.1&SRCLANG=de&TRGLANG=en
It has been found that the power consumption of a Ökolampe(=CFL) without the inventive device to 24 W is approximately 23, while falls within the inventive device the consumption to 1 W or less.
Baquero Menendez ~ Paul Marzahn configuration x 3
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20100615&CC=ES&NR=2341161A1&KC=A1
their numbers and bringing to 2021
          20-30-45% converter efficiencies and f.e. Marzahn-chamber instead Mylar-reflector Hyperstealth foil  output improving  !
       17,4 TW :                7 KW primary power (W,not Wh = energy) as electric power (W ,not Wh = energy)
        per private household global :
        1 sqm/cbm area/space need
                                                       Anymore commercial provider/consumer power-lines
btw : incandescent lamp 4% light conversion and 96% heat/thermic ( is the filament in the bulb/globe not in evacuated  atmosphere ? 8) )
                                     4% photo               and  96% phono
                           From 155 TWh per annum/year primary energy use global (all sources) to per hour : 17,4 TW
        per household
                           we can assume in average actually maximal  50 % efficiency over all conversion processes
                           so we get by the 50% losts reduction energy ( nearly 90% efficiency ) =
                            3,5 KW primary power (W,not Wh = energy) as electric power (W ,not Wh = energy) per household
                          now the improving from all electric appliances( motor/generator/transformer/heater/cooler) by/to 50% less consume
                          < 2 KW primary power (W,not Wh = energy) as electric power (W ,not Wh = energy) per household
                          and in this 155 TWh per annum are all consumer :
                         industry/commerce/power plants(own consume)/militar/
                         public orgs/companies and the private households
                        as future global average power installation
