Passive Power Amplifier Patent US8653903
Started by ZL, June 29, 2016, 07:16:00 AM
ZL
During a recent patent search for free energy related microwave inventions I have stumbled across a patent, which is quite thought provoking, and perhaps some researchers on this forum may be interested to take a look at it. It is the United States Patent 8653903, titled: "Passive Amplifier" Publication Date: 02/18/2014, which will be attached to this post.
According to the inventors Kenneth J. Schlager and Jason Zehrung, the device is a passive circuit composed exclusively of resistors, capacitors, and inductors, employing a positive feedback. The circuit was originally developed to serve as a low noise passive amplifier for radio- and microwave frequencies, but they have allegedly also tested it at low frequencies of 60 Hz as well, with success.
If they would claim that it amplifies power in a passive way (which means it generates excess free energy) at microwave frequencies only, then I would get curious and examine it in detail. But they have gone too far by claiming that this circuit can generate free energy even at 60Hz, which would mean, that you could just plug it into the power outlet and connect your electrical appliances to the amplifier output. Then voila! You have the simplest, cheapest, and most efficient free energy generator in the world for a few bucks that every technically minded person could build at home from off-the-shelf components. Doesn't this sound too good to be true? Well, it does to me.
If I am so skeptical about it, then why post it here at all? Well, because it is an excellent demonstration of the disinformation campaign perpetuated in the field of free energy by the energy cartel. They do everything they can to confuse free energy researchers (and people in general) by approving patents for alleged free energy devices, which don't generate free energy in reality (like this one); while denying patents to devices that really generate excess energy in practice (like the invention of Janos Vajda). Then they spread hoax free energy inventions on forums, to lead the interested researchers into blind alleys, and in round circles, never arriving to success; away from any real free energy principle, which could really work in practice.
How do I know that this can not work at low frequencies? First of all, please note that the inventors did not even touch the subject about which principle generates excess energy in their circuit. Then note that the science of electronics (and its computerized simulations) of these passive components is advanced enough to know, that at low frequencies there is no way to amplify power and generate excess energy with such passive circuits. If you don't believe me, then try it!
Why would I be inclined to check for any excess power at high frequencies? Because at high frequencies power is not conducted in the same way like at low frequencies. At low frequencies all linear components affect each other quasi-instantaneously in real time, and the reciprocal coupling between the components prevents the generation of any excess energy. At high frequencies the wave length is small enough that the power propagates in the circuit as a wave, and therefore the laws of wave propagation dominate. One of these laws is the law of superposition, which does not only allow the generation of free energy, but it also guarantees this to happen in properly designed circuits. I will write about this subject more in another thread that I will start now about free energy from wave fields.
So this patent is posted here as a contrast to the patent application of Janos Vajda which has been denied. The patent application of Mr. Vajda will be discussed in more detail in the mentioned other thread.
Despite my skeptical opinion, if anybody is interested to test this extremely simple circuit in a computer simulator or build it in practice, it will be interesting to see the results. Here are some excerpts from the patent below.
Zoltan Losonc
Abstract:
A passive amplifier for use with enhanced power supplies, signal preamplifiers and power amplifiers in communications systems particularly in mobile phones, laptop computers and other battery-powered and battery-limited devices. The passive amplifier can be used as an attachment to electric appliances or other power consuming equipment to significantly reduce the electric power requirements of such equipment. These passive amplifiers do not require an outside source of power and can be used to elevate battery power outputs and serve as either low noise signal preamplifiers or transmit power amplifiers for higher performance and extended battery life. Passive amplifier technology is either electromagnetic or dielectric in nature with component parts limited to inductive, capacitive and resistive components. Dielectric amplifier prototypes have gain values in the range of the 10 dB level so as to be useful in communications applications and power amplification.
BACKGROUND
Although the low power usage amplifier was initially proposed for communications applications as described above, a second major market exists in the electric power (energy) saving market. The same passive dielectric amplifier may be designed for operation in the 60 Hz frequency band and used to save energy through attachment to electric power consuming appliances, such as refrigerators, electric heaters and lighting fixtures. In an embodiment of an amplifier with demonstrated power gains of 4 to 1, a 500 watt appliance with an attached passive dielectric amplifier would consume only 125 watts.
SUMMARY
The present disclosure relates to passive amplifiers for application as energy saving power supplies, signal preamplifiers and power amplifiers in communications systems particularly in mobile phones, laptop computers and other battery-powered and battery-limited devices. The passive amplifiers also have application as an energy saving attachment to an electric appliance. These passive amplifiers do not require an outside source of power and can be used to elevate battery power outputs and serve as either low noise signal preamplifiers or transmit power amplifiers for higher performance and extended battery life.
Passive amplifier technology as proposed here is either electromagnetic or dielectric in nature with component parts limited to inductive, capacitive and resistive components. Dielectric passive amplifiers are particularly desirable because of their easier extension to higher frequency RF and microwave communications and their potential for miniaturization. The basic dielectric amplifier technology has been proven theoretically and by simulation and bench experimentation. The dielectric amplifier prototypes developed in accordance with the present disclosure are able to increase the gain of the amplifier to at least the 10 dB level so as to be useful in communications applications.
Currently, the basic dielectric amplifier function of the disclosure has been verified theoretically and by follow-on simulation and bench experimentation. Single stage prototypes were designed, constructed and tested at 60 Hz and 100 kHz. Simulation studies have been carried out at 100 kHz, 915 MHz and 2.4 GHz. Paper designs have been completed up to 5.8 GHz. In each case, the dielectric amplifier has demonstrated significant power gain without the need for an outside power source. The only requirement is an input signal in communications applications or a lower power input in electric appliance applications.
Various other features, objects and advantages of the invention will be made apparent from the following description taken together with the drawings.
Really interestant ! Also for body e-cooling/warming clothes !
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20120524&CC=WO&NR=2012065719A2&KC=A2
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=5356484A&KC=A&FT=D&ND=3&date=19941018&DB=EPODOC&locale=en_EP
By way of example, an input signal of 6 microwatts with a bandwidth of 1 gigahertz is applied to diode 20 either as thermal energy or electric energy, and thermal energy is applied to diode 10. A signal-to-noise ration of 60 dB is obtained for the input signal for a temperature Tc of the cold diode 20 of 300 DEG K. For a temperature Tr of hot electrons in diode 10 of 6000 DEG K., the amplification of the input signal is 26 dB, which gives an output signal of 2.4 milliwatts. The amplified output signal also has a 60 dB signal-to-noise ratio.
the conversion process,amplifying effect: 6  microwatts to 2,4 milliwatts
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=DD&NR=287597A5&KC=A5&FT=D&ND=3&date=19910228&DB=EPODOC&locale=en_EP
Probably in future there will be an heat-electric cycle in each home installed -off grid/intra-grid- based.
Gothic
Quote from: ZL on June 29, 2016, 07:16:00 AM
And your here to save us from ourselves?
patent attorneys search the claims of the applied patent against previous
claims from other patents and decide if the claims don,t infringe...
It can take up to five years to get one plus numerous fees.
Usually if someone has a product they wish to produce while maintaining
a measure of protection they will pay a fee and file Patent Pending.
this type of person has something that works and wants to get the item
to market asap...
You can file a patent on almost anything, they look at, you pay and as long as
it is unique or a previous claim has expired it,s yours, working or not...
an example is this patent
US20030209636 BOBBIN ELECTROMAGNETIC FIELD PROPULSION VEHICLE
Inventor: John Quincy St.Clair, San Juan, PR
Correspondence Address:
John St.Clair
Hyperspace Research Institute
52 Kings Court, 4A
San Juan, PR 00911 (US)
Appl. No.: 10/142,583
Filed: May 9, 2002
Publication Classi?cation
ABSTRACT
This invention relates to a spacecraft Which generates its
oWn magnetic moment and magnetic ?eld gradient in order
to produce lift on the hull. The magnetic moment is gener
ated by a large area solenoid located in the hull. A toroidal
core Wrapped With electrical bobbins at intervals along said
core produces a traveling magnetic Wave along its surface.
This magnetic Wave creates a spacetime curvature, similar to
a tilted plate, Which causes the formation of a magnetic ?eld
gradient. PoWer is not critical because the system uses a
magnetic vortex Wormhole generator to loWer the speed of
light in order to efficiently create highly relativistic ?elds
due to LorentZ transformation.
Now do you believe this guy has a wormhole generator...
http://www.dummies.com/how-to/content/the-patent-process.html
ZL
Nice finds lancaIV, it could be worth taking a deeper look at these heat converting patents, if I would have time for that. Perhaps someone else will take the challenge.
Did you test any of these ideas and devices whether they really generate excess energy, or just efficiently convert heat into electricity? When the refrigerator was invented, people thought about that also, that it was a free energy generator, because the heat pump produced more output power than the required electrical input.
These inventions could slip through the patenting process either because they don't generate any real excess energy, or if they do, then it is not significant enough to threaten the interests of the energy cartel. The invention of Mr. Vajda could not get the patent, because that would have turned the present status quo of the energy industry upside down. He sued the patent office, and lost the case. He even had the balls to persevere and appeal to the Supreme Court to obtain justice, and get his patent, but as you would expect, it did not succeed. The real great FE players don't get any patent, no matter how well they present the invention, how much money they have for the process, or whatever they do.
The patent system has been established by the elite to serve their own interests, not that of the public. They just create a false appearance that its all there to serve the little people, to prevent opposition and rebellion.
Hello ZL,
no ! I never did realized a prototype based by the offered Yater,Reichelt publikations !
My interest has been and is the electromagnetic spectrum and the possibilities,macro and nano-universal !
http://www.infinite-energy.com/images/pdfs/GraneauEditorial94.pdf about "inner energy",distance/time related and the observations !
also really inspiring:
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20140917&CC=CN&NR=104047814A&KC=A
To demonstrate the ratio between kinetic energy and internal energy we calculate these energies for a relatively strong wind of 25 meter/second (the maximum operable wind speed of the V80 2 Megawatt wind-turbine) having a temperature of T= 32<0>F, which is quite cold air in the populated northern hemisphere in the winter, where such air turbines are popular-
Using the British Unit System Cp=6000 FT x LB/Slug <0>R T= 460+32 =492[deg.]R V= 25/0.3048= 82.02 FT/SEC
The internal energy is: Cp T= 6000 x 492=2,952,000 FT x LB/Slug The kinetic energy is: V<2>/2= (82.02)<2>/2=3,201.6 FT x LB/Slug
Therefore the ratio between the air kinetic energy to the air internal energy in this case is: 3,201.6/2,952,000= 0.00108, i.e., the kinetic energy is about one thousandth of the air internal energy and this case is for the maximum operable air speed for the sophisticated 2 MW air turbine. Weaker winds yield even smaller energy ratios.
Since 2008 I am in contact with the slovacian physician Dr.Pavel Imris,Csc. ,working out the potential from electromagnetism !
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=pavel+imris&IN=&CPC=&IC=&Submit=Search
One of his last trials:
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=20150618&CC=DE&NR=102013021483A1&KC=A1
[0022] Zum Beispiel, in Reihe 3 sind 140 V Spannung und 6,66 Ampere Blindstrom. Bei 50 Hz Frequenz ist die Blindleistung 935 VA und die abgegebene Wirkleistung ist 850 W. Die aufgenommene Wirkleistung in den kapazitiven Wicklungen 3 , 25 , 26 ist24,31 W.
                                                               out: 850W in: 24,31W
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20091130&CC=PT&NR=104078A&KC=A
english:
https://worldwide.espacenet.com/publicationDetails/originalDocument?FT=D&date=20091223&DB=EPODOC&locale=en_EP&CC=WO&NR=2009154492A2&KC=A2&ND=4&pageNumber=2
From the description you will see that the application is against the written laws ,consequence: new conditioning from the laws !
