car energy consume improvements
Started by lancaIV, July 02, 2016, 07:40:03 AM
Qwert
Grrrrreat!!
Those prototypes are not only light, they also require light people to drive them, no passengers, of course; what about jokeys as drivers? and of course, they'll never hit the roads:too weak and crumble for any road regulation. I repeat: everything is in torque. Yes, they are great as novelty, and nothing practical.
Qwert
Sorry LancaIV I spoiled your enthusiasm.
This motor looks really as a good idea. The only problem is with that claim, which says that to move a car, conventional ICE needs 1500 RPM, while this one needs only one RPM for the same effect. IMO, in this concept there must be an equivalent of those 1500 RPM: the adequate air pressure for example, which causes this, is produced by a motor which require adequately equal energy, and that will be more than just 1 RPM to produce adequate pressure (how many strokes of a compressor you need to get an air pressure of 100 psi in a tank in which the initial pressure is zero? It depends on torque of the compressor); no magic.
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fripower-elektrofahrzeuge.de%2Felektroauto-umbau-kosten%2F
Engine and Power 30 KW electric motor drive ~ 95 KW/130 hp ic engine.   Newton*meter equivalence
http://www.prismz.com/homebuilts/   https://www.vortechonline.com/scorpion/index.html        135 hp ic engine Scorpion- 133
Flying two-seater electric cars are in the 30 KW electric drive class
Summasumarum in future selling price beginning with 5.000 Euros ( Scorpion-I : 170 Kg weight icl.  Ic engine)
                                      Conventional electric drive conditioning
              With new electric motor technology ,magnet array and parallel path :
                                 f.e. SCHILLER , QMPower,Thorq,Geminielectric
                                        twice the torque by same electric power
                                      15 electric KW motor street and flying cars
                https://www.voanews.com/a/can-better-electric-motor-save-planet/4235140.html
                                       Electric motor torque out versus electric input
  Simple calculation by known parameters : https://simplemotor.com/calculations/
                                    http://maddsci.tripod.com/george/id11.html
                        " .... factor of at least 1000 in terms of torque out for watts in ..... "
                    http://www.epi-eng.com/piston_engine_technology/power_and_torque.htm
I do not know which numbers of real Jakelj electric motor performance teste he, Alan Heglund, is refering and comparing !
                          Outperformer ?  By the above " theoretical 1000/1 ratio"
                                and comparing with Hitachi,Siemens,GeneralElectric,Raser,QMpower,......        e-drives ? Absolutely !
