car energy consume improvements
Started by lancaIV, July 02, 2016, 07:40:03 AM
adrouk
And what method is used to obtain ammonia as alternative to hydrogen ?
onepower
SL
Quote"Simply put doubling the voltage cuts the current by half at any given power level"
If this were a "Transformer" device, I would agree (minus the losses); but this is a "Boost Convertor,"
not a transformer, [plus 200-300 Vin - 400-800 Vout].
This is the mistaken assumption most (all) guys made when evaluating the Holcomb devices!
Anyway, I'll just leave it there...
Of course I'm not talking about a simulation or assumptions but building, using and testing hundreds of DC/DC converters. In fact I used a DC converter in my two capacitor paradox tests and posted the data at OUR seen below. Capacitors don't lie, in the graph C1 and C2 is measured in Farads and E1 and E2 energy in Joules.
The science is very easy to understand, in a boost converter the input power(V x I) produces a magnetic field. When the same magnetic field collapses in induces a voltage and current output proportional to the magnetic field change. The voltage and current can change but the power remains unchanged minus the losses.
AC
Ammonia is nitrogen and hydrogen mixed  !
https://www.autocar.co.uk/car-news/new-cars/gac-and-toyota-develop-ammonia-engine-90-co2-reduction
https://m.youtube.com/watch?v=Pcm4fCDQ4dY&pp=ygUJI2VuZ2luZXdzMazda also in ammonia engine car R&D ,Ford did have participation in the Mazda company .
100 US$/KW the aquariusengine !
Remembers the 'Stelzer Motor ' !
https://en.m.wikipedia.org/wiki/Stelzer_engine
As really cheap range extender : the Reinhardt engine-genset
https://dreamer3000.wordpress.com/the-reinhardt-turbine/
10 US$/KW the 2008 engine costs estimation !
https://www.greencarcongress.com/2009/04/concept-compact-twocycle-cogenerating-pistondriven-turbine-to-deliver-60-efficiency.html
Comparison Reinhardt/INN  :
https://m.youtube.com/watch?v=HcC8mPoYe8g
Toyotas ic engine mass production costs are near 10 US$/KW !
We shall not forget ic engine fuel kind conversion R&D :
6 lt/100 Km water hydrolysis ic engine :    https://m.youtube.com/watch?v=Hi4EZikqXJE
wmbr
OCWL
Cloxxki
Quote from: Paul-R on September 15, 2023, 06:44:34 PM
AC is right. You have no more idea than Trump who said, during the winter, that it was cold and some global warming might not come amiss.
We all know that people who bring in Trump on a totally unrelated topic are the true sages of the early 21st century...
You do realize that you're volunteering to compare me to the single most popular man in the most powerful country on the planet? Plot twist: you actually didn't know but you hate two people now so you feel there is nothing more natural than to associate them to each other for a very far fetched reason.
If that's what you intend to use as a "burn", you might be THE person to help us all figure out alternative fuels...
Trivia: Why are Canada and Europe no longer under a thick ice sheet?
Answer: Actual climate change happened.
Bonus: Same answer applies to a lot of things I doubt you're well aware of, considering the chilling burn you volunteered.
Cloxxki
Quote from: lancaIV on September 17, 2023, 10:50:58 AM
Found: "the exhaust gas from the actual ammonia-fueled engines contains unburned ammonia, nitrogen oxides (NOx), and nitrous oxide (N2O), and there is a need to develop technologies to remove these harmful substances."
NOx is what is crippling the farming and construction sectors, depending on local brand of politics.
[/size]
