free energy = AC electricity can be multiplied with pulleys
Started by that_prophet, July 02, 2016, 11:44:27 AM
that_prophet
free energy can be multiplied with pulleys
USE PULLEYS TO MULTIPLY ROTATIONS = AC ELECTRICITY
What this Christian Warrior is trying to get out to the world,
is the simplicity of tHis Gift.
Free Energy is here + now, even free of all patent fees =
please Goggle free_energy + yolasie.
http://free-energy.yolasite.com/
free energy can be made simple,
you can use pulleys to multiply your electricity
instead of using oil to generate it
free energy is here now,,,
It is all done with pulleys. (mirrors of physical properties)
you use a small amount of electricity to rotate a very large pulley only the once,
then you get many times the power back out,
from the one or few generators connected to the same belt as the large pulley,
(rotating tens to hundreds of times the large pulley) all on the same belt
If you would like to know where this warrior is coming from,
please check these pages out :
http://beliefstoliveby.yolasite.com/
http://fire-starter.yolasite.com/
for my mission, Please view any of these Bible web pages:
http://doorschristmustpassthrough.yolasite.com/
http://decimationofthisevolutionfairytale.yolasite.com/
http://askthatprophet.yolasite.com/
but no one will listen to the simplicity of it
all you do is put power into a motor to turn a large pulley only one revolution
and then you get massive amounts of electricity back
from the many small pulleys attached in the same belt
Please realize the dark conspiracy covering this subject, yes this is dirt simple, almost too simple to work,,, yet it does indeed work, you just need the faith to try it. Seriously, just try it out, and you will get to see the workings of one of His Miracles. Please, don't let this miracle be hidden any longer. Let us start using the technology of Ezekiel to change the world for the better.
It's workings are super simple
You put power into a motor to drive a large pulley only once (little energy)
+ You get out a multiple of that electricity
Depending on how small the generator pulleys are
As well as how many generators with little pulleys attached
With the amount of belt that goes around one large rotation
You can easily get 10 – 20 times the rotations of the input pulley
Then you can double your rotations each time you add yet another generator
On your own belt system, (easily done – takes little torque)
I figure, you simply must gain a multiple of the energy that you put in
As you are only putting enough power into the drive motor to rotate it only once
And you get back many times the electricity
Not only having smaller pulleys,
But gaining more rotations per foot of belt that you go through
To double or tripling your rotations by adding additional generators
on their own mini-pulleys
Free Energy is such an obviously simplistic discovery,
- as well as being extremely free + easy to produce,
what is the only reason for us missing this basic idea,
- we have been dumb to this free energy technology .
This technology has been hidden for far too long,
Please, go to this website
Search free-energy + yolasite
Or if this website allows URLs
then try your hand at producing a digital prototype
on one of the many free electronic simulator software's out there,
that will help start producing electric toys + tools,
and how about everything that runs on electricity,
being reproduced with free energy power supplies built into them.
Let's restart our economies,
by building industries that reproduce all of our electronics,
so that they are all self powered. (non polluting)
= First though, is getting rid of all the gasoline motors in our motorized vehicles,
and putting a GEM in them.
All we need to do, is have enough faith in His Word
to build these GEM (Good Electricity Multiplier) Miracle motor
THIS DOES INDEED WORK
(think about how simple this is)
(you put power in to rotate one large pulley once)
(you run a belt to rotate mini-pulleys many time)
(then you could add many mini-pulleys)
(each one rotating hundreds of times)
(multiplying your AC electricity)
(YOU MUST GAIN FREE ENERGY)
LOGICAL REASONING
It takes little energy to turn a one foot circumference pulley,
which can be used to drive a belt that turns a mini pulley
of one inch circumference many times
This 12X you gain your AC energy from the many times the small pulley rotates,
or even more from the many generators on mini-pulleys you add (no torque)
you can twelve times the AC electricity with every extra genertator attached
12X + 12X + 12X + 12X each starts to add up very quickly
all of these generators run free of any torque
come on guys + gals, this is so simple that it just has to work
you only put the small amount of energy to rotate a big pulley once
and you use pulleys to multiply your rotations many times
you could have ten mini-pulleys rotating hundreds of times
you simply must gain electricity
the torque is your only problem
and that would be minimal
if you only had a 12 inch circumference pulley
then you have 3 mini-pulleys
rotating 36 times for each one rotation of your large input pulley
YOU JUST HAVE TO MULTIPLY YOUR ELECTRICITY
Originally Posted by Tom C
well its time for you to make something not just an electric wheelchair... please build it and put some meters on it...
Tom C
sorry Tom, but I happen to be poor + disabled, with shaky hands, so I cannot build it myself, nor can I afford to pay someone to build it for me
FREE ENERGY is so super simple. It only take one spark of DC electricity, to rotate a DC motor once, with a 100cm circumference pulley attached, giving you 100cm of moving belt, strap, rope or string. Then if you run this moving belt through 1 to 10 mini-pulleys of one centimeter circumference, you would get an output of 100 to 1000 cycles of AC electricity. There is no torque resistance from the mini-pulleys, as there is no current involved, or practically none, considering that to make this mechanism a self powered mechanism, you only need one spark of DC output to be sent back into the DC drive motor. These AC generators are just winding up massive voltages, which is all that you need to turn over your drive motor one single time.
This FREE ENERGY mechanism is in need of one more very important component, a full wave bridge rectifier, to convert your AC output generators into DC electricity, which is needed by your drive motor. I should state them as plural, just in case you have plural mini-pulleys, which would increase your total ability to tap power off of, both your AC or DC motor/generators. Once started running, (easily achieved by giving your large pulley with the DC drive motor a quarter turn by hand) this AC + DC power supply should be a perpetually running mechanism.(until the bearings dry out or some other mechanical break down)
FREE ENERGY is so super simple, that there simply MUST be something or someone,(evil forces) hiding it from the public eyes. Yes, there are in reality, two parts to this subject: (1) - how super simple this technology really is + (2) - how evil forces have an immensely powerful hold on this technology. First I will prove to you just how super simple this technology is, + second how powerful of a hold that Satan + his followers must have on our modern society, to be able to keep this technology hidden.
This FREE ENERGY mechanism is in need of one more very important component, a full wave bridge rectifier, to convert your AC output generators into DC electricity, which is needed by your drive motor. I should state rectifiers as plural, just in case you have plural mini-pulleys, which would increase your total ability to tap power off of, both your AC or DC motor/generators. Once started running, (easily achieved by giving your large pulley with the DC drive motor a quarter turn by hand) this AC + DC power supply should be a perpetually running mechanism.(until the bearings dry out or some other mechanical break down)
Now you should be able to tap AC or DC electricity off either motor, or maybe even both. If you find that you cannot get much current out of either of the motors that you are tapping off of, then all you need to do is add more of your mini-pulleys with the AC generators attached. Diagrams can be viewed at http://free-energy.yolasite.com/
free energy
This works by using, one spark of DC electricity is all that is needed to start this mechanism running = DC motor with large 100cm circumference pulley turning only one single time. The 100cm of belt is then run past mini-pulleys of one centimeter circumference, gaining 100 units of AC electricity. The pulley combinations multiply you total # of rotations, which when AC generators are added, becomes AC electricity.
TWO BIG POINTS ABOUT THIS BLESSED BIBLE BORN MIRACULOUS MECH
(1) – You can add as many mini-pulleys + AC generators as you would like, because these add no torque with their rotations. Torque comes from power generation = Voltage X(times) Current, and since we need only a spark of current, (practically none) to feed back into driving you DC motor, this negates the massive voltage you are generating with massive rotations of your generators. By the way, this massive voltage=pressure that you are easily generating with your massive rotations of your AC generators, is exactly what you need to push over your large drive pulley the one single time.
(2) – This Bible description,(Vision) that I was Given by God = (discovered), can be used for generating free energy, was from how a UFO motor looked while running. This could mean, if you are determined, that this mechanism might lead to anti-gravity + 1000 km/hr vectoring. Just think about this part of His GEM= (Geometrical Electricity Multiplier) of a Gift. Not only is this free energy good to help stop polluting our earth, but we could pay one time to build free electricity driven filters,(that run cost free) to help clean our atmosphere + water.
I know that most will reject this part of my description of how I came up with this Miraculous mechanism, but I still feel that I MUST state these awesome facts. This is a Gift from the God of our Holy Bible. He first gave me this in a Vision of a ten speed going uphill in 10th gear,(few rotations of pedals) and then back down the hill in first gear, (massive rotations of pedals). Since AC electricity is generated from rotations, I figured that the more rotations meant the more AC electricity you were multiplying.
I then took this logic and converted it, to perform a test with my electric wheelchair. I started out with a low battery, and went up a long steep hill as fast=(10th gear) as I could, until my battery died and my chair would not go any further up the hill. Then I went back down the hill slowly=(1st gear), until I got back to my starting point. I then repeated this action three times, of going uphill fast + back down the hill slowly, and each time I gained the power to go up the hill an extra 20 feet. So the 3rd time that I repeated this action, I was 60 feet higher up the steep hill. I had miraculously gained the power to go up this steep hill an extra 60 feet. Please remember, to have this experiment work on most any electric wheelchair, you must first change the settings on your electric wheelchair, to maximum torque,(1st gear) + maximum speed,(10th gear).
I was still unsure of Who had given me this Vision, so I ask my Lord for proof that this was from a His Spirit and not from evil spirits, trying to mislead me. I was shortly directed to Ezekiel 1:16, where the Word Stated plainly, "a (small)wheel in the middle of a (large)wheel". I did not have the technology nor money to build it exactly like it was stated, but I devised a simple way to used pulleys and a belt, strap, rope or string, that would simulate it.
I have been Shown many more important bits of information that can be found at http://beliefstoliveby.yolasite.com/ but my most important discoveries are here:
http://my2020vision.yolasite.com/
http://aliensandghosts.yolasite.com/
Paul-R
Dear Stefan,
Your site has almost 17,000 threads, most buried beyond any hope of discovery and yet you allow this hopeless idiot to start up more on his absurd nonsense to drown even more thoroughly those that exist.
Please ban him.
that_prophet :
We know about Chas Campbell. We don't need you. Build your machine and prove us all wrong BEFORE you bore us further with your rubbish.
FatBird
Absolutely won't work.  Try it & see.
ZL
Quote from: Paul-R on July 03, 2016, 09:06:36 AM
Dear Stefan,
Please ban him.
Paul-R has a very strong point here. It is absolutely trivial to recognize that this is just another deception perpetuated by the energy cartel, and this post of mine is not about adding one more vote to the "this is an obvious hoax" box. Rather, the intent is to add some input about how to handle such situations, and how to battle the overwhelming assault of hoaxes.
Some of the old and experienced FE researchers already know what is going on in this field of online research. But it might be useful to highlight some aspects of the hard reality to the enthusiastic young researchers, who still think that everything is just fine, and there is no suppression. Let me paste here a paragraph that I wrote in another thread with some modifications:
The strategy of the energy cartel's disinfo organization is not too complicated: infiltrate the FE movement, establish your own puppet "authority" figures with intense advertisement, and mislead the herd into blind alleys. Channel their investments into waste bins, and make them fail over and over again by replicating the disinfo garbage "FE inventions", which should flood the internet. They should be so numerous, that the few real FE inventions should be lost in the heap of garbage, unrecognizable. This will lead the herd to utter frustration, and finally tired out and broke, they will become either idle passive watchers of the FE news, or just quit the research completely. Discredit the concept of FE by creating FE fads like Kapanadze, Keshe etc. and finally by busting them as hoaxes. Then people will finally associate all FE inventions with hoaxes, saying "... nahh! Not again! Here is yet another hoax, from another crackpot. Just ignore it!"  And of course, the most important of all is to ignore and suppress the real guys, who invent real FE generators and/or spread the science about it. This is what has happened to Janos and me.
To bring FE to the masses it is not sufficient to only invent an FE machine. If that would be enough, then we would not be paying electricity and heating bills since at least the times of Tesla, and we could live in a paradise-like world of plenty. The inventor also has to mobilize enough money to enable the development of the invention for mass production, which is not pocket money; and it is next to impossible to get the "big money" to invest in FE. The third obstacle to overcome is the relentless disinformation campaign, and intense anti-free-energy brainwashing in educational institutions, mass media, patent offices, online websites, forums, and elsewhere, perpetuated by the energy cartel.
It is no wonder that no FE inventor has succeeded so far with breaking though all 3 of these obstacles. If the masses, or the representatives of people (we) don't help such inventors, and don't get big money interested in investing in real FE development for mass production, then there is really no hope for success. Then even after hundreds of years your descendants will live in a terribly polluted radioactive world, still using fossil fuels and radioactive materials for energy production and transport, and they will blame us for not having done anything (or enough) to ensure their energy independence, freedom, and good health, while there was still chance for success. Like we could blame our ancestors for not doing more, to protect our freedoms form the oligarchy, while they were less powerful than they are today. If we don't find a way to dispel the dense fog of confusion and ignorance spread by the disinfo organization, then who will do that? The inventors? That is not their job, it is not their field of expertise; they have better things to do.
We are mostly taking this subject easy, thinking that we are not obliged to move our little finger to help real FE inventions succeed, because it is just a hobby to us, and no one is paying us for this. But just think about it a little deeper! There are about 7 billion people on this planet, and if you count how many of them are interested in FE research, you will hardly pressed to find a few thousand or perhaps few 10000. Out of these, may be only a few hundred that is really doing something useful. If we are not obliged to dispel the dense fog of disinformation, find real FE inventions in the huge pile of hoax and idle chat, and get it into mass production, then who will do that? The inventors can't do it on their own, I hope you realize that. The rest of the 7 billion people will not do it because they are not interested, and/or too ignorant in this field to do anything. So the only people with the responsibility to fight this battle for the future generations is only us. If we don't do our duty, then your descendants will live in a terrible world as slaves terribly sick, living very short lives, with microchips implanted in their bodies.
Therefore it is absolutely necessary that FE researchers educate themselves in the art of disinformation, so that they should be able to recognize the agents of the energy cartel, and subdue their campaigns successfully. They are present everywhere, and if you think that this forum is an exception, then you are still asleep, having a rosy hypnotic dream. For the starters, here is a very informative introduction to the techniques used by the disinfo agents:
http://vigilantcitizen.com/latestnews/the-25-rules-of-disinformation/
After this little introduction, let's return to the suggestion of Paul-R to ban this user for spreading an obvious hoax. If this forum would be mine, I would surely do that, and I would ban not only this fellow, but many others as well. But then of course, the forum would not be so popular as it is now, and there would be less (or no) money for running the forum, and due to the lack of popularity perhaps many of the genuine members would not be here either.
As far as I am aware, the policies of the forum don't forbid the posting of hoaxes either, so basically this banning exclusively for this reason is a mute point. It would be also very hard for Stefan to decide whom to ban and who may stay in many cases where the deception is not so trivially obvious like in this case.
So here is a suggestion about what could be done to at least somewhat counter the disinfo operations on this forum.  Genuine researchers (not disinfo agents) supposed to dig out the potentially valuable inventions and threads from the heap of 17,000 threads, and put them on a list. Every member could have his/her own list. These lists could be posted in a thread specifically started for this purpose only, without comments to keep it information-dense and undiluted (no idle chat and off topic comments). Unfortunately the undercover disinfo agents could also post their bogus list, so this is far from a perfect solution, but it still can reduce the 17,000 threads to say few hundred potential threads. In a smaller heap of straw it is easier to find the golden needle.
Another additional filter could be then a poll, where forum members could give their votes at an independent poll-web-platform, which of these lists they trust and which they don't (preferably obliged to explain the reason for their votes). This poll again can be (and will be) contaminated with the bogus votes of disinfo agents, but still, it can be a useful information, that could further narrow down the numbers of potentially genuine FE inventions.
Further filters could be implemented based on objective merits of the selected few potential inventions. Like:
1. Is there any scientific – mathematical proof that they can produce FE based on the conventionally accepted rules of physics?
2. Was a proof-of-concept device already built?
3. What were the measurement results on such device?
4. Did anybody succeeded to replicate those measurement results, or at least attempted it?
5. What are the critics saying about such replications?
6. Is the principle of excess energy generation known for that invention?
7. Is there any need for an exotic new theory to explain the process and/or origin of FE; if yes does such theory already exist? Is it plausible; does it make good sense?
8. Can the device generate enough FE to supply at least the needs of a household?
9. How expensive is it to produce it; is it economical at all?
Etc.
Another, extremely important project could be to collect all the FE inventions that have already been proven to be hoaxes by honest replications, or by other reliable logical and scientific methods. This will again not be a perfect list, because it will again be contaminated by the disinfo agents, but still, it can help filter and narrow down the list of potential hoaxes to avoid.
When all these statistical and analytical data is available and well developed, then Stefan can have an easier job to decide on his own responsibility, which threads and inventions could make to the new category of "Most Probably Genuine FE Inventions" where those selected threads could be again categorized according to those categories where they have been found and properly belong (one ex. like "Solid States Devices"). Another new category could be ,,Most Probably Hoax FE Inventions". As already mentioned, the final result of all this filtering system will not be perfect, there may still be useless inventions in the "Genuine" category and genuine inventions in the "Hoax" category, but I hope you agree that a lot of useless junk, and idle chat will be filtered out and it will be easier to find the real thing in a smaller heap. The content of these categories don't have to be fixed either. They can be modified any time as soon as sufficient proof or reason emerges to remove or add some threads into these categories.
Also, I don't believe in the 100% efficiency and usefulness of "democracy" when it comes to FE research and its promotion. The democratic voting system (just like the popularization of certain FE inventions) can be very easily manipulated and results falsified by the energy cartel. This is the reason that the final decision about what gets into the final categories should be made by the owner of the forums and websites, and not decided solely by a voting system. This way personal responsibility can motivate the owners, to recognize and counterbalance any possible manipulations of the mentioned filters, or vote results.
This way hopefully there will be no need to ban people just because they post obvious hoaxes, while still helping researchers to find the real things they are looking for; and counter the overwhelming onslaught of disinfo hoaxes that steal the attention, time, and money of genuine researchers, and create untold frustration.
ZL
Just in case the page at the link I gave in my last post disappears, here are the rules reposted:
QuoteFrom Twenty-Five Ways To Suppress Truth: The Rules of Disinformation (Includes The 8 Traits of A Disinformationalist) by H. Michael Sweeney. These 25 rules are everywhere in media, from political debates, to television shows, to comments on a blog.
    1. Hear no evil, see no evil, speak no evil. Regardless of what you know, don't discuss it — especially if you are a public figure, news anchor, etc. If it's not reported, it didn't happen, and you never have to deal with the issues.
    2. Become incredulous and indignant. Avoid discussing key issues and instead focus on side issues which can be used show the topic as being critical of some otherwise sacrosanct group or theme. This is also known as the "How dare you!" gambit.
    3. Create rumor mongers. Avoid discussing issues by describing all charges, regardless of venue or evidence, as mere rumors and wild accusations. Other derogatory terms mutually exclusive of truth may work as well. This method works especially well with a silent press, because the only way the public can learn of the facts are through such "arguable rumors". If you can associate the material with the Internet, use this fact to certify it a "wild rumor" which can have no basis in fact.
    4. Use a straw man. Find or create a seeming element of your opponent's argument which you can easily knock down to make yourself look good and the opponent to look bad. Either make up an issue you may safely imply exists based on your interpretation of the opponent/opponent arguments/situation, or select the weakest aspect of the weakest charges. Amplify their significance and destroy them in a way which appears to debunk all the charges, real and fabricated alike, while actually avoiding discussion of the real issues.
    5. Sidetrack opponents with name calling and ridicule. This is also known as the primary attack the messenger ploy, though other methods qualify as variants of that approach. Associate opponents with unpopular titles such as "kooks", "right-wing", "liberal", "left-wing", "terrorists", "conspiracy buffs", "radicals", "militia", "racists", "religious fanatics", "sexual deviates", and so forth. This makes others shrink from support out of fear of gaining the same label, and you avoid dealing with issues.
    6. Hit and Run. In any public forum, make a brief attack of your opponent or the opponent position and then scamper off before an answer can be fielded, or simply ignore any answer. This works extremely well in Internet and letters-to-the-editor environments where a steady stream of new identities can be called upon without having to explain criticism reasoning — simply make an accusation or other attack, never discussing issues, and never answering any subsequent response, for that would dignify the opponent's viewpoint.
    7. Question motives. Twist or amplify any fact which could so taken to imply that the opponent operates out of a hidden personal agenda or other bias. This avoids discussing issues and forces the accuser on the defensive.
    8. Invoke authority. Claim for yourself or associate yourself with authority and present your argument with enough "jargon" and "minutiae" to illustrate you are "one who knows", and simply say it isn't so without discussing issues or demonstrating concretely why or citing sources.
    9. Play Dumb. No matter what evidence or logical argument is offered, avoid discussing issues with denial they have any credibility, make any sense, provide any proof, contain or make a point, have logic, or support a conclusion. Mix well for maximum effect.
    10. Associate opponent charges with old news. A derivative of the straw man usually, in any large-scale matter of high visibility, someone will make charges early on which can be or were already easily dealt with. Where it can be foreseen, have your own side raise a straw man issue and have it dealt with early on as part of the initial contingency plans. Subsequent charges, regardless of validity or new ground uncovered, can usually them be associated with the original charge and dismissed as simply being a rehash without need to address current issues — so much the better where the opponent is or was involved with the original source.
    11. Establish and rely upon fall-back positions. Using a minor matter or element of the facts, take the "high road" and "confess" with candor that some innocent mistake, in hindsight, was made — but that opponents have seized on the opportunity to blow it all out of proportion and imply greater criminalities which, "just isn't so." Others can reinforce this on your behalf, later. Done properly, this can garner sympathy and respect for "coming clean" and "owning up" to your mistakes without addressing more serious issues.
    12. Enigmas have no solution. Drawing upon the overall umbrella of events surrounding the crime and the multitude of players and events, paint the entire affair as too complex to solve. This causes those otherwise following the matter to begin to loose interest more quickly without having to address the actual issues.
    13. Alice in Wonderland Logic. Avoid discussion of the issues by reasoning backwards with an apparent deductive logic in a way that forbears any actual material fact.
    14. Demand complete solutions. Avoid the issues by requiring opponents to solve the crime at hand completely, a ploy which works best for items qualifying for rule 10.
    15. Fit the facts to alternate conclusions. This requires creative thinking unless the crime was planned with contingency conclusions in place.
    16. Vanishing evidence and witnesses. If it does not exist, it is not fact, and you won't have to address the issue.
    17. Change the subject. Usually in connection with one of the other ploys listed here, find a way to side-track the discussion with abrasive or controversial comments in hopes of turning attention to a new, more manageable topic. This works especially well with companions who can "argue" with you over the new topic and polarize the discussion arena in order to avoid discussing more key issues.
    18. Emotionalize, Antagonize, and Goad Opponents. If you can't do anything else, chide and taunt your opponents and draw them into emotional responses which will tend to make them look foolish and overly motivated, and generally render their material somewhat less coherent. Not only will you avoid discussing the issues in the first instance, but even if their emotional response addresses the issue, you can further avoid the issues by then focusing on how "sensitive they are to criticism".
    19. Ignore proof presented, demand impossible proofs. This is perhaps a variant of the "play dumb" rule. Regardless of what material may be presented by an opponent in public forums, claim the material irrelevant and demand proof that is impossible for the opponent to come by (it may exist, but not be at his disposal, or it may be something which is known to be safely destroyed or withheld, such as a murder weapon). In order to completely avoid discussing issues may require you to categorically deny and be critical of media or books as valid sources, deny that witnesses are acceptable, or even deny that statements made by government or other authorities have any meaning or relevance.
    20. False evidence. Whenever possible, introduce new facts or clues designed and manufactured to conflict with opponent presentations as useful tools to neutralize sensitive issues or impede resolution. This works best when the crime was designed with contingencies for the purpose, and the facts cannot be easily separated from the fabrications.
    21. Call a Grand Jury, Special Prosecutor, or other empowered investigative body. Subvert the (process) to your benefit and effectively neutralize all sensitive issues without open discussion. Once convened, the evidence and testimony are required to be secret when properly handled. For instance, if you own the prosecuting attorney, it can insure a Grand Jury hears no useful evidence and that the evidence is sealed an unavailable to subsequent investigators. Once a favorable verdict (usually, this technique is applied to find the guilty innocent, but it can also be used to obtain charges when seeking to frame a victim) is achieved, the matter can be considered officially closed.
    22. Manufacture a new truth. Create your own expert(s), group(s), author(s), leader(s) or influence existing ones willing to forge new ground via scientific, investigative, or social research or testimony which concludes favorably. In this way, if you must actually address issues, you can do so authoritatively.
    23. Create bigger distractions. If the above does not seem to be working to distract from sensitive issues, or to prevent unwanted media coverage of unstoppable events such as trials, create bigger news stories (or treat them as such) to distract the multitudes.
    24. Silence critics. If the above methods do not prevail, consider removing opponents from circulation by some definitive solution so that the need to address issues is removed entirely. This can be by their death, arrest and detention, blackmail or destruction of their character by release of blackmail information, or merely by proper intimidation with blackmail or other threats.
    25. Vanish. If you are a key holder of secrets or otherwise overly illuminated and you think the heat is getting too hot, to avoid the issues, vacate the kitchen.
