Graham Gunderson's Energy conference presentation Most impressive and mysterious
Started by ramset, July 11, 2016, 07:00:18 PM
poynt99
Quote from: TinselKoala on July 24, 2016, 12:29:40 AM
Obviously I disagree.
The input to the transformer is indeed switched or cycled, that is, the H-bridge is being clocked at a definite mix of frequencies. It is not simply providing a +/- voltage input to the transformer. As Smudge has determined, the H-bridge waveform is a sinusoid at 75 kHz but is being chopped or switched or gated at 50 kHz so that the "input" to the transformer is one full cycle of a near-perfect sinusoid (from an H-bridge!) followed by a dead time equal to one half-period of the sinusoid. See the attached scopeshot below.
I didn't say the input to the transformer was a +/- voltage. What I did say was that the h-bridge is the power source for the input to the transformer. In terms of the input power measurement, the wave form going into the transformer is irrelevant (the scope setup will handle anything thrown at it). The H-bridge is simply the power source (with a custom wave form), nothing more.
"Back end" would be referring to the synchronous diode circuitry I think.
In terms of input power measurement the waveforms are irrelevant because the scope can handle anything thrown at it... but in terms of the device operating as claimed, the waveforms are _very_ relevant. Supply it with DC for example.... the scope measures this power just fine, but the device will not work. It must be supplied with the correct waveforms in order to work, and in order for the "input power" to be "zero" the waveforms must have a specific relationship.
As Smudge has pointed out, the "input power" as seen by the scope is a result of multiplying two waveforms that are almost exactly 90 degrees out of phase. This is why they result in a "zero" average power measurement.
If this is considered as the "input power" to the device, then I am happy to report that I have a handful of devices here in my lab that also count as massively OU, because the "input power" measured at the primary coil is also made up of current and voltage waveforms that are 90 degrees out of phase, hence resulting in a "zero" average input power. Yet the secondary outputs of the air-core transformers will light up bulbs, charge capacitors to high voltage, even run motors.
So by the same logic that seems to be applied here, I have had these "OU" high COP devices sitting around for years already. And they are simple and cheap to build, require no "unobtanium" parts, have been fully described and demonstrated and I am still willing to discuss them.
So wherz my 2 million cheezburgerz?    ;D
http://www.google.com/patents/US7830065 (whom belongs  the patent rights ? Chava ( Energy ) Llc ?)
The mechanical action of an electrical generator is thereby synthesized without use of moving parts.
ttps://patentscope.wipo.int/search/en/detail.jsf?docId=WO2016070292
VOLTAGE SYNTHESIZER BASIC BUILDING BLOCK CIRCUIT DIAGRAMS
minnie
ramset
Minnie
Start a forum of your own and hang your name on the door and start calling out known persons by their full name and associate them with things which they had nothing to do with.
It has no place here ,and is unethical to say the least .
And criminal in most countries .
MileHiigh did this at OUR and got the owner in trouble with lawsuit threats.
And to be clear the threats were well on their way to realities...
If you have issues about how Stefan runs his forum perhaps you should ask HIM about these things ?
Or start your own...
Respectfully
Chet K
PS
I see Minnie's request below ,I am traveling and working out of town .
I will Gladly Discuss this upon return .
And to be PERFECTLY CLEAR ,I have never asked for Miles to be banned [and Specifically stated that when I was Speaking with Stefan]. ,I too appreciate his technical contributions .
However If his contributions become a personal liability to Stefan .
That's a no Brainer ...
Thanks Grandma
