Graham Gunderson's Energy conference presentation Most impressive and mysterious
Started by ramset, July 11, 2016, 07:00:18 PM
Vortex1
To add another dimension to the argument of whether the H bridge can be replaced with a power function generator, it would only be true if the function generator could provide an open condition to the tank circuit during the 33% dead time. Normally a FG will present a low impedance output to a DUT when programmed for zero output e.g. during the dead time. So the H bridge may be unique by "letting go" of the tank during this period.
  I am not familiar with power function generators capabilities, or whether it can provide the open condition so I tried driving the tank from a Voltage source executing a PWL (piece wise linear function)using a PWF file in LTSpice. The results do not match up with the same  pulse sequence driving an H bridge.
I used the same values and timing as Spokane1's sim except only 5 cycles at +/-200 volts. The 200 volts was so that I could get some juice into the rectifiers 1N5817. I realize I may need more than 5 cycles.
So this is a single ended drive from a pseudo FG. Next I'll show an actual  FET H bridge.
This is a first rough shot at it. I'll post all my results and more detail as time permits. forgive the errors.
green =drive
blue = tank voltage
red =tank current
ramset
The conference Movie has been released By Aaron
and here is a comment from member Partzman [reposted with permission]
Partzman
I have finished watching Graham's MIT video and IMO, he really does give enough info to replicate.
Several points of note, when the input current as shown on CH2 (blue) reaches the negative peak, the primary core is saturated. At the flat top portion of the waveform, the primary core is at a higher permeability.  The core bias is set of course by the PMs.
During the negative half cycle of the input voltage on CH1, the first pair of opposite H bridge switches are on and during the positive half cycle the second switch pair are used which is already known. However, during the remaining part of the input cycle when the core is in a high perm state, the second pair is left on and conduction is thru primarily the mosfet reverse conduction.
The synchronous mosfet switching uses both normal and reverse conduction and may have already been pointed out but not that I recall. While current is flowing thru the mosfet in the normal mode that is, when conventional current flow is from drain to source, the gate is switched off for a short period producing a large positive going voltage spike on the secondary. Also during this time, the secondary current and flux reverses
direction as is seen in the green channel and when the peak reverse is reached, gate voltage is again applied to the mosfet which now conducts in the reverse conduction mode that is, from source to drain with very low resistance. This action is what results in the output caps being charged negatively as shown. Graham also stated that the output current phasing is 180' from that shown.
Regarding the issue of the current connections on the input Clark/Hess power analyzer, he removed the original connections well after he had explained the operation of the device and all the input/output measurements. He made the change during a time he was explaining another aspect of the device.
The secondary core half is operated in a mostly linear mode while the primary core half is operating around the saturation knee. This seems to be a key prerequisite in the appropriate flux flows (or magnetic vector potential) along with the proper output synchronous timing.
I can now understand how a small capacitance added to the gates of the output synchronous mosfets could destroy the OU effect
end quote""
The link to Energetic forum is in the first post of this thread
and here is the link to Graham's talk mentioned above,
it is a "for sale" item ,with a percentage going to Graham.
http://www.energeticforum.com/renewable-energy/20547-magnetic-implosion-transformer-graham-gunderson.html
respectfully
Chet K
Thanks Grandma
ramset
Vasik
Here we do not look for a nicer fitting shoe or a fancier hat ...or ..
and honestly,  assumptions of nonsense ,thievery, skullduggery or just plain error have ruled the day.
However
here we have something which Most have asked for [and never gotten at this forum]  a properly presented claim
being tested by a properly qualified person using properly qualified test equipment.
having worked for test labs all my life , I realize the gaping holes in the above statement .
before the Page fills with
NOT or disagreement or claims of BS we must at the very least appreciate the opportunity to investigate this claim as presented ...which does indeed seem quite Mysterious .
that being said
Did you expect a red carpet a marching band and a guy to install it in your house
for free ??
welcome to the Grind of blindfolded investigation of world changing technology's... a path filled with distractions
dead ends and countless carnival hawkers .....
But  "some day" ??
please be respectful as there are very talented fellows donating their very talented time and money ..to do the best they can to understand what is taking place here .
and those fellows are not charging you a dime ...
you want shoes ??
that's middle of isle 5 left side bottom shelf ..
you wanna change the world ??
That's isle two
the line forms outside over there by that guy in the pink tutu holding that sparky thing with the pink unicorn wearing a black leather mask [yes we have many different pink unicorns ,very popular...
I'm not sure whats sparking but don't get too close....
just another day...??
maybe not !!
you want to talk about _your_ world changing technology ?
Please Start a thread.. it truly does sound interesting. [isle seven next to the guy handing out sun glasses.
8)
respectfully
Chet K
Thanks Grandma
vasik041
Quote from: ramset on August 05, 2016, 05:11:52 AM
Vasik
However
for free ??
But  "some day" ??
you want shoes ??
That's isle two
maybe not !!
8)
respectfully
Chet K
Please don't be upset, but my point is that I don't see the reason why I should pay money (buy DVD) for a chance to test something. There are plenty of good ideas around...
It's my opinion.
