Faraday paradox revisited,magnetic field rotation question.
Started by PolaczekCebulaczek, August 05, 2016, 04:09:24 PM
PolaczekCebulaczek
yes and magnet needs to be ceramic, because iron or neo can induce current in itself (if field is stationary) , speeding or slowing current inside magnet = e field.
just two more questions:
1. homopolar generator produce steady DC current ??(no emf near disk) what about rpm changing?
2. this one is kinda related to this topic... if charges flow inside wire, in loop in clockwise direction and i will rotate this loop in counterclock direction, what would happen ? protons would move against electrons that are moving too? and if i rotate this loop in clockwise (the same direction that current flows ) what then?
lumen
Quote from: Magluvin on August 15, 2016, 05:26:15 PM
So lets say if the probe was on top above the spinning magnet and a neg charge triggers the probe, would there be a pos charge under the spinning mag?
I was thinking that you could place the probe wire near the midpoint on the outer diameter of the magnet but not touching the magnet.
If the field is spinning with the magnet then the electrons should move along the conductor and trigger the detector.
The charge would change depending on the rotation direction of the magnet. CW might move electrons toward the detector and CCW would move them away.
minnie
   If you lot want to see a real homoplar generator just look into the work of
  Mark Oliphant and his "Big Machine".
     Just goes to show that there was a huge understanding of the principle
  many years ago.
   As early as 1934 a homoplar generator was put into service for welding tube
  at a stell mill.
          John.
guest1289
    If this thread   Stopped  because they thought that they were starting to contradict the current-laws -of-science, or self-suppression,  then that is silly ,  because the following threads were started by the site-admin :
    http://overunity.com/15864/friedrich-luling-magnet-motor/
    http://overunity.com/16782/mit-graham-gunderson-video-release-of-the-conference-demonstration/
    The second thread,  is about a functioning device demonstrated at MIT university.
    (  The two examples I have given,  could possibly be poor in comparison to other functioning-devices,  currently discussed on this website,  and publicly demonstrated  )
     Suppression was effective before the internet and mobile-phones etc,  not anymore.
     However, I doubt that  Overunity-Home-Powering-Generators  will ever be available from shops or  large-online-retailers,  and not  pre-assembled.
______________________
    My Only Question Is :
      -  If you have a  'Free-Spinning-Disc-Magnet' on a shaft,  and then you bring a  'Straight-Wire-Carrying-Non-Pulsed-DC-Current'  near( but not touching ) to one-half of the 'Disc-Magnet'( OR, to the surface of the outer-edge of the 'Disc-Magnet' ),  WILL IT CAUSE THE 'DISC-MAGNET' TO SPIN  ?
    The diagram-below shows my question,  the large-circle is the Disc-Magnet,  and the wire is labelled X.
