Thanks to ALL for your help!!
electric bike/scooter motor
Started by lancaIV, August 07, 2016, 02:49:33 PM
jhewitt03041976@gmail.com
e2matrix LOL, I do so apologize, God only knows how, but I meant to put "Watts", I feel dumb, sorry for my inadvertent typo, yah, I'd LOVE a 450 HP electric motor for $60, I could do 120 mph while hauling 2 tons of load, LOL, thanx for telling me sir.
a 450 Watt motor is not very powerful, if the total weight of the rider, bike, motor and batteries are less than 180lbs, your good to go, but for experimenting with converting for use with generation, I prefer gearless btw, less resistance from the friction of the gears themselves
Low-Q
Quote from: jhewitt03041976@gmail.com on June 27, 2018, 01:38:54 PM
I have watched the evolution of the brushless hub motor over the past 20 years with great enthusiasm, and as they have become more powerful, more efficient and a hell of a lot lesser cost, I seen some reliable 450hp motors for less than $60, I have loved it, the ONLY problem is power, the batteries are probably the #1 hindering factor, the price of quality & reliable batteries is ridiculous, I working on a project that would use the principle of regenerative braking, having one wheel with a motor that also supports regenerative braking, but have another more powerful motor converted for the sole purpose of regeneration, it won't produce an Overunity effect, but I think more people will buy e-bikes if they can get twice the distance on half the power from a battery that's also half the weight (free bonus)
I have made myself an e-bike with a large gearless hub-motor. It is rated to 800 Watts, but when I look at the specs for the brushless motor on my 1/8 scale truggy, that small sized motor is rated to deliver 2800 Watts peak.
The e-bike battery pack consist of 10S 30C LiPo with a 60A BMS with bluetooth connection to Android phone. Batteries are bought at Hobbyking.com.
The electric current readings peaks 75A@40Volt at full throttle from slow speeds, or approx 3kW with tremendous torque at that low RPM. The rear hub motor is very powerful, but is for sure capable of much more power without damage. The only concern is the spokes between the hubmotor and the 28 inch rim.
From the three phase motor connectors, it is possible to regenerate some power. So I have bought a 1500Watt step up converter and a three phase rectifier. The converter needs at least 10VDC in to work. The rectified three phace is pretty damn smooth. I did a test with it and the regeneration works great. However, the temorary wirings looks like an IS-bomb, so I need some time to clean up the wiring :-)
Another concern is the input current to the converter. If I want to charge the battery with 6A at 36-42V, I need an input current at 24A. 6A charging current isn't much, so by tuning this up to 10 or 15 A we are talk 40-60A input at 10V which is not very practical amd the converter is limited to 30A input current, while input voltage is rated from 10V to 60V. Output up to 85V.
Vidar
https://citkar.com/en/
https://translate.google.com/translate?sl=auto&tl=en&u=https://citkar.com/de/shop/details-loadster-pick-up/
Rated continuous                           250 W (1.3 kW)
output  (maximum output)
Battery capacity                                2 x 800 W
Charging time per battery                  3-4 hours
Total Range                                       50-60 Km
by average 25 Km/h this means by given range 800 Wh/25 Km consume
improving with :
BATTERY CAPACITY                                           2 KWh
CHARGING TIME                                              15 minutes
reference : https://www.log9materials.com/two-wheeler.html
and the range doubling by
https://worldwide.espacenet.com/publicationDetails/originalDocument?FT=D&date=20100114&DB=EPODOC&locale=en_EP&CC=WO&NR=2010003394A2&KC=A2&ND=4
by average 25 Km/h  100 Km range = all 4 hours recharge (if not 500W net on-board recharger for nonstop driving )
                                                   statutory break from work and fast recharge time !
                               alternatively : 500 VAh/Kg - 1000 VAh/Kg battery later ,8 hours drive capacity ( = 1 work-turn )
                                                         the progress I :
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.mdr.de/wissen/klima/verkehrswende-lastenrad-autonom-100.html
                                                         the progress II :
https://www.google.com/search?q=paris+30+km%2Fh+consultation&rlz=1C1AVFC_enPT930PT930&oq=paris+30+km%2Fh&aqs=chrome.1.69i57j0i22i30l9.11324j1j7&sourceid=chrome&ie=UTF-8
                                       it is : Paris - 31.87 km / h       will be : Paris - 30.00 km / h
                                                        Really shocking  :o  ( ::)  )
from trike/3-wheeler to quad/4-wheeler            https://www.sumsolutions.it/en/
assumption :
when
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20001207&CC=DE&NR=10011074A1&KC=A1
1,5 KW rated electric motor with 220 Volt is enough for given Km/ h speed and vehicle weight
then
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19840807&CC=US&NR=4464095A&KC=A
by dividing the rated e-power in cw-unit and ccw-unit ,not 1500 W rated /2000 W consume (75% efficiency) /2 but /4 =
                                      2x( 1x cw and 1x ccw) 500 W AC drives,each with capacitive winding
and on-board 500-1000 W rated
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=20070201&CC=ES&NR=2265253A1&KC=A1  generator battery-set
                                                 as later "autonomous nonstop driving quad" (  speed max. 50 Km / h regulated )
https://en.wikipedia.org/wiki/Sinclair_C5     rated 250 W DC motor
https://citkar.com/en/                                rated 250 W       motor
autonomous = unmanned and energy autarc = self-recharging vehicle concept :
here rated 1500 W by 220 Volt AC motor ( look for citkar rated W and maximum W !)
this AC motor energy consume improved :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=21&ND=3&adjacent=true&locale=en_EP&FT=D&date=20110609&CC=DE&NR=112009002191A5&KC=A5
and
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20200205&CC=MX&NR=2019010053A&KC=A
AC electricity delivered by
https://www.patentsencyclopedia.com/app/20090079393
My invention generated several times the power it consumes to operate and does so by an all electric means with no moving parts.
                       factor out/in 1,5 is more than enough ( at first )
and battery set recharged by drive
https://www.patentauction.com/patent.php?nb=15379
Btw : all this publications are mostly "open source" or only national rights applied !
Free experimenting by law allowed !
For STANDART2100 Mobility-Share-Cityeggs  ;)    https://pbs.twimg.com/media/Dx2W2MyVAAIhrpt?format=jpg&name=small
for pure e-bikes :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=volkrodt&CPC=&IC=&Submit=Search
from all his inventions,partial for SIEMENS, concentration to :
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3003026&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
and the question : applyable ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20070201&CC=JP&NR=2007028879A&KC=A
description translated :
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=JP&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=2007028879&OPS=ops.epo.org/3.2&SRCLANG=ja&TRGLANG=en
