LUA Script in FEMM 4.2 - please help!:-)
Started by Low-Q, September 08, 2016, 04:46:36 PM
Low-Q
Hello,
Some years ago I got great help from someone here who was a racer in LUA scripts. But those scripts I saved in my old computer, which is pretty much out of service now.
I need help to make a script that measure torque of a group made in FEMM 4.2. I have read the FEMM 4.2 manual, but I cannot understand what script to use, or where to put them in right order.
I want to keep the original file, so the script must save the results as another file.
For group 1 with center X0 - Y0, I need 0.8 degree steps starting at 0 degrees, ends at 71.2 degrees (At 72 degrees the result will be the same as 0 degrees)
For group 2 with center X0 - Y1, I need 1 degree steps starting at 0 degrees, ends at 89 degrees (At 90 degrees the result will be the same as 0 degrees)[/size]
Can someone please help? Any help is very much appreciated :-)
Vidar
I used a script that I've used myself a while ago and modified it for your needs, please be aware it's not tested but I think it should give you a decent start :) .
Besides generating data it also generates an image of every simulated step which can later be converted to an animated gif file if you want.
showconsole()
--Defining the variables
dAngle=0.8    -- Increase of angle ( Degrees of rotor rotation by step )
totalDegrees= 72 -- amount of total degrees to roate
X0 = 0
Y0 = 0
open("myfile.fem")
mi_saveas("temp.fem")    -- Temp file for save the original
mi_seteditmode("group")
data = {};
for n=0,((totalDegrees/dAngle)-1) do
    alfa=dAngle*n
    print(alfa) -- print to console for debugging and showing the progress
    --analyze the current rotation and take image
    mi_analyse(1)
    mi_loadsolution()
    mo_showdensityplot(0,0,0.5,0,"mag")        -- Obtain Image
    mo_savebitmap(format("acgen_%1$d.bmp",alfa))  -- Save Image
    --Calculate the torque
    mi_analyse(1)
    mi_loadsolution()
    mo_groupselectblock(1)
    torque = mo_blockintegral(22)
    --gather all data
    data[n] = {}
    data[n][1] = alfa
    data[n][2] = torque
    mo_close()
    -- write results to disk for further analysis, make sure the file already exist to write the results to
    fp=openfile("results.txt","a")
    write(fp,data[n][1],"\t" .. data[n][2],"\n")
    closefile(fp);
    mi_selectgroup(1)            -- Select Rotor group
    mi_move_rotate(X0,Y0,dAngle)        -- Rotate the rotor
end
Low-Q
WOW! I can't thank you enough :)  This is awesome!
Thank you broli!
Vidar
Low-Q
I tried it, and I think it need some minor modifications. I got an error message. Please see attached picture :-)
showconsole()
X0 = 0
Y0 = 0
open("GE.FEM")
mi_saveas("GEtemp.FEM")    -- Temp file for save the original
mi_seteditmode("1")
data = {};
    alfa=dAngle*n
    mi_analyse(1)
    mi_loadsolution()
    mi_analyse(1)
    mi_loadsolution()
    --gather all data
    data[n] = {}
    data[n][1] = alfa
    data[n][2] = torque
    mo_close()
    closefile(fp);
end
Low-Q
I made a mistake in "group"...at the beginning. It works now - just have to add script for group 2 because these two groups are colliding :D
