Thanks to ALL for your help!!
FE in the news / new FE offer
Started by lancaIV, September 09, 2016, 08:23:04 PM
penno64
Hope tinman has a crack at this.
Just like his rt
What he has to say ?
https://www.youtube.com/watch?v=_-J46dxOEv0
40 minutes ? someone can translate it for the audience ?
https://www.youtube.com/watch?v=q5z7_1m9p6g
                                              300%
tinman,rt ?
https://www.youtube.com/watch?v=gfPef4Q2jkg  reminds http://rexresearch.com/alxandr/alexandr.htm
In practice, the primary D.C. motor windings are of fewer turns in the rotor slots than the secondary A.C. generator windings. For example the primary motor windings 10 are flat wound between north to south poles of the field while the secondary generator windings are flat wound in the same or common slots of the rotor armature. In a typical unit having a four brush commutator with 20 bars and having a 20 slot armature, the primary windings 10 are comprised of a number of turns of conductor to efficiently draw 48 volts D.C. at 25 amperes or 1200 Watts to rotate at 1750 RPM; while the secondary windings 11 are comprised of a number of turns of conductor to efficiently deliver 60 cycle (by transforming and generating) 110 volts A.C. at 32 amperes or 3520 Watts; the volt meter used to read these values upon an actual reduction to practice being calibrated to read the root-mean-square (rms) value of the pure sine wave, which is 70.7% of the peak voltage.
Pardon moi,tagor,mais espanhol ce nest pas ma longue maternal,ne pas aussi paternal  !
Je compris ,mais quarente minutes :P
Olli und concentration ! Hyper-activity ;)
