Thanks to ALL for your help!!
FE in the news / new FE offer
Started by lancaIV, September 09, 2016, 08:23:04 PM
Quote from: memoryman on September 17, 2016, 03:18:02 PM
Yes,  do.
however, this site is called OU.COM, not higherefficiency.com
Is highest efficiency <= 1 not enough ,for the beginning ?
Reading this http://www.geminielectricmotor.com
From reply #14 :
A. 20 Amps @ 110Volts of Power generally equates to approximately 1 HP in a typical AC motor.
and
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=meta+c&IN=&CPC=&IC=&Submit=Search
"going"(".." not bodily but mental) to this
https://worldwide.espacenet.com/publicationDetails/description?CC=MY&NR=137586A&KC=A&FT=D&ND=3&date=20090227&DB=EPODOC&locale=en_EP
Test results using a motor configured as in FIG. 4 are as follows:
TABLE 6Readings  Readings  Workat 410  at 410  PerformanceBaseline  Three Phase  20.5 psi  Implementation462  V  462  V  1.7  A  1.6  A552  W RMS @  185  W RMS @  20.5 psi  watt meter    watt meter
B.552  W per hour  185  W per hour
summa summarum: A/B = (745/2200)/(185/552)
                                                   The perfect unity electric motor or generator using resonance concept.
        MEV = perfection trial
        The over-gain cycle not yet disclosed
p.s.: If you think that OU is a possibility, good luck . You'll need an infinite supply of that...
         me do satisfy finite supply of luck,I am not and will not become imortal=infinite
1.sun light to photovoltaic electricity
                                                        +  https://www.patentauction.com/patent.php?nb=12841
wind to electricity
2.
concentrated sun light          https://www.patentauction.com/patent.php?nb=11175
                                             http://www.inpama.com/index.php?content=invention&id=1068
wind to electricity
3. sun light to electricity
concentrated wind to electricity         https://www.patentauction.com/patent.php?nb=9374
4.artificial sun light to electricity        http://www.inpama.com/index.php?content=invention&id=660
   artificial wind to electricity              https://www.patentauction.com/patent.php?nb=9318
https://en.wikipedia.org/wiki/Genrich_Altshuller died 1998.
His WIPO patent archive research let him stating that 95% of all problems resolving solutions had been discovered and documented.
(probably the rest-5% to find here: http://www.proquest.com/products-services/pqdtglobal.html
  each work-result for fee-/licence-free use,dissertations are ever "open source",beginning with their publication  )
Now we have 2018 : all the meant patent object claims are now -twenty years after- "open source".
                20Amps@110 Volts of Power generally equates approximately 1 HP in a typical AC Motor
                  https://www.electronics-tutorials.ws/de/actheorie/effektivspannung.html
                  https://whatis.techtarget.com/definition/root-mean-square-RMS
                 a.  Voltp / Volteff : 0,7071
                 b1. FEMF positive= productive Volt phase / BEMF negative= unproductive Volt phase 0,5
                 b2. Voltp-p/Volteff : 0,354
                2200 VA.        = 1 HP  AC shaft force
               20 Amps x ( 110 Volts x 0,354 )                            = 1 HP  AC shaft force
              + power factor correction
              The Voltp and Voltp-p to Voltaverage for : sinus wave
              The Voltp to Voltaverage for pulsed DC has his own corrections factor for average DC power
Thinking to have an output/input surplus generator and connect this with a capacitive, resistive, inductive load
let only by work and time process and the measureable result showing : real circuit/ grid efficiency < or > 100%  !
             https://en.m.wikipedia.org/wiki/Duty_cycle
           Showing the change using for rectangular waves only " sinus wave peak to average correction "
          2200 VA 100% duty cycle = 1 HP AC shaft work   or  1 HP DC-equivalent
           4400 VA   50% duty cycle = 1 HP AC shaft work   or 1 HP  DC- equivalent
           8800 VA.  25% duty cycle = 1 HP AC shaft work   or  1 HP DC- equivalent
          Numeric overunity ratio is not physical overunity
