free energy is done using pulleys
Started by that_prophet, September 17, 2016, 05:32:19 AM
that_prophet
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS THE GEM OF AC ELECTRICITY MULTIPLIERS
GEM=(Geometrical Electricity Multiplier)
that_prophet
Can you believe that I was first given this technology in 2000 or 2001, + soon published it on the web @ http://free-energy.yolasite.com/
citfta
that_prophet
Quote from: citfta on October 16, 2016, 04:44:52 PM
Your device is useless!
Thank you for your useful insight,,,,,,,,,,,,,,,,,,
THAT IS WHY I CALL THIS AN AC ELECTRICITY MULTIPLIER
Lenz law sounds like something electronic, when this works om simple pulley mechanics = 100cm circumference pulley only turns once
+ this gives you 100 turns, X,(times) the # of 1cm circumference pulleys that you attach.
If you attach AC generators to each of these 1cm mini-pulleys,
you would gain 100 units of AC electricity, for every 1cm pulley that you attach.
This could be massive amounts of free AC electricity,
if you added 10's of these mini-pulleys then you would gain 1000's of units of AC electricity,
all done with one spark of DC current, (practically zero)
that_prophet - Re: use pulleys to multiply total # of rotations = AC electricity
Quote from: citfta on October 14, 2016, 01:05:13 PM
I don't understand how you can be so dense.  You have had numerous people tell you that your idea will not work.  That is because we actually have experience working with motors and generators.
REPLY BY ME
I don't understand how mankind be so dense, to not see that this use of pulleys does not involve torque, but simple multiplication of rotations = multiplication of AC electricity. The AC generators are just winding up massive voltage, to turn over your DC motor, only the once, + no current, as you only need one spark to have this self powering.
Now try and tell me that you would not be able to get one spark of DC output,
when you have 1000's of units of AC electricity to work with
citfta
MOTORS DO NOT RUN ON A SPARK OF ELECTRICITY!!!!  You say you first published this in 2001 and yet NO ONE has been able to get it to work.  Please study the links I gave you and you will understand why it cannot work like you think it will.
