Never reducing propellant for deep space propulsion tech
Started by vikram_gupta11, September 25, 2016, 02:09:02 AM
vikram_gupta11
In this sketch there is a GUN SYSTEM as a propellant chamber and we are using IRON BALLS as a propellant.
An electromagnet is attached on the other side of this engine .When we fire these   IRON balls  with the help of this gun system then these balls will move towards forward side and a back force will be create to propel  this engine .  These iron balls will be piled up on the surface of this electromagnet and we can again reuse these iron balls and send back these iron balls into the propellant chamber or refilling the Gun system again and again with the help of a mechanical system .
In this way this engine will work  and  the propellant (IRON BALLS) will never be reduced.
Now please tell me that will this Idea work or not as this time as far as I think no law is violating.
Floor
The guns "kick" is equal to and opposit the projectiles impact.
vikram_gupta11
Dear  Floor sir,
you are right that this will not move as net force is Zero but I have a question that suppose if the iron balls could reduce its velocity  with itself and hit with electromagnet with low velocity then this engine will move or not?
suppose the iron ball is expelling with 5 meter/second speed from Gun system and is hitting the electromagnet or a wall with 2 meter /second velocity then this device should work or not?
further more I would like to inform you that we will use FERROFLUID(magnetic fluid) to reduce the velocity of these Iron balls .These iron balls will be filled up with this magnetic fluid  and at the time of  expelling this fluid will be in solid state but once expelling from the gun system it will convert into liquid form to reduce the velocity of iron balls .In this way this iron ball will reduce its velocity with itself due to ferro liquid.
we can also use another system to reduce the velocity of iron ball upto 0%by using two electromagnets .In this solution suppose iron ball is moving through between two electromagnet  and these two electromagnet will try to attract this iron ball  and this iron ball will be stopped immediately.
Now my question is  now the velocity of this iron ball is Zero then this engine should move or not  as we are getting thrust of gun system to propel the engine and iron ball is in 0 velocity and the force has been canceled  to stop this iron ball due to both electromagnet  .
Please explain your answer.
i shall be very grateful to you.
Vikram
Floor
@vikram_gupta11
I do not say, that here is no way to acomplish what you are seeking.  NASSA has recently
verified the functionality of a device which is at least (some what) similar to your concept
But your most recent explination of the device is unclear to me.  I think that without a good drawing of
your concept, both you and I may be unclear in regard to its working or not.  Draw it and you my be able to
decide for your self if it is workable.
  floor
vikram_gupta11
Dear Floor Sir,
Can you please tell me that from where I can get more information that nasa has verified  a device similar(some what) to this concept?
Please tell me some link .
