PATENT - UTILITY Model(l)- COPY-RIGHT - OPEN SOURCE
Started by lancaIV, September 26, 2016, 07:30:16 AM
Thaelin
   Had that program on my RS mod1. After beating on it for a while, I got told to go jump in the lake.
To confuse it, just answer a question with a question.
Quote from: Thaelin on March 28, 2022, 03:18:12 AM
Hello Thaelin,is this not "very human" in day-by-day male/male female/male   ../...  behaviour ? ::) Un-/experienced ?!
How often :  :?  :!  versus          :?  :?  ;)
wmbr
OCWL
https://overunity.com/6763/energy-amplification/3555/    page 239/240,.......
as applicant Daniel de Beauupre
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=charles+de+beaupre&IN=&CPC=&IC=&Submit=Search
as inventor Daniel de Beaupre
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=charles+de+beaupre&CPC=&IC=&Submit=Search
extracting
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19220721&CC=FR&NR=540979A&KC=A#
to the description the "mosaics" :
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=FR&NR=540979A&KC=A&FT=D&ND=3&date=19220721&DB=EPODOC&locale=en_EP#
as inventor Marcel Meredieu
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=marcel+meredieu&CPC=&IC=&Submit=Search
extracting :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19291018&CC=FR&NR=667647A&KC=A#
Pour concevoir et réaliser la présente in  vention, ii   fallait d'abord trouver une inter  prétation neuve du phénomène mai connu  de l'induction  électrique.
    L'énoncé de cette interprétation est né  cessaire pour définir exactement les carac  téristiques essentielles  de l'invention, de  manière   intelligible,  soit : .
1 Le flux inducteur, issu d'un foyer  quelconque (pile, accumulateur, etc.)   re-      foule  le milieu   ambiant,    comme  le ferait la force centrifuge d'un   volant    en  rotation.
    2  Le flux induit .(ou, pour mieux dire,  le reflux) issu du milieu extérieur, révèle  l'énergie   imxqense  mise en jeu, durant   les oscillations  de la masse   fluididique  spa  tiale revenant vers son équilibre normal.   Ii   s'assimile à la force centripète de l'air, sol licitée par la rotation d'un volant.
    3  L'énergie induite (qualifiée centri  pète), est toujours plus puissante que   celle (qualifiée centrifuge) ou inductrice qui est  la cause perturbatrice de l'équilibre  spatial.
    4  La   puissance  du courant induit  (capté dans l'espace) est en proportion di  recte de la sensibilité  de   l'instrument  ré  cepteur et de sa capacité électrique.
    5  La bobine d'induction   actuelle,  for  mée de deux circuits   indépendants  et rap  prochés (primaire et secondaire) comprend  un récepteur commode et très   sensible  qui  est le circuit secondaire ou   induit  .
    6  La capacité électrique dudit récep  teur dépend de deux facteurs :   tension  et intensité;   l'élévation  de la tension étant di  rectement proportionnelle  au nombre de  spires induites,   multiple  de celui des spires  inductrices (ce qui est   connu),  et essentiel  lement, l'élévation    simultanée  de l'inten  sité étant directement proportionnelle  à la      surface de section du   conducteur  induit, in-      dépendamment  de la puissance du   flux   inducteur et du calibre du conducteur pri  maire (ce qui était   insoupçonné).
Toutes    les  machines   d'induction    ac-      tuelles    (dynamos, alternateurs,   transforma-      teurs,    bobines  de   Ruhmkorff, etc.) sont     considérées    comme  de   simples    transfor- mateurs  de   l'énergie  (travail en chaleur,     électricité,    basse tension-  en haute   tension,   etc., et   inversement).  En réalité, la   pré-      sente    découverte  démontre que le flux in  ducteur et le flux induit sont deux formes  opposées de l'énergie (l'un centrifuge,  l'autre centripète) et que la   bobine  d'induc  tion bien comprise   n'est  pas un simple     transformateur,  mais un merveilleux    multi-      plicateur    d'énergie.  La puissance remar quable de   l'étincelle  de   rupture  confirme     pleinement  cette théorie  et prouve que le  flux induit   (centripède)  est toujours plus énergique que le flux inducteur (cen  trifuge).
    Le présent dispositif, conforme à cette  conclusion   théorique,  se caractérise   essen-      tiellement  par   l'emploi,    dans  la bobine    d'in-      duction,  d'un gros   fil    secondaire, c'est-à-      dire  d'un   conducteur  induit de surface de  section calculée  en   vue    d'élever  l'intensité  (parallèlement à la tension)  du courant       transformé,  et non. de   réaliser  l'une au dé-      pens  de l'autre, comme le veut le   rapport dit<B>e</B> de transformation<B> </B> actuellement    ap-      pliqué  aux bobines de   Ruhmkorff.
https://en.wikipedia.org/wiki/Garfield_Wood
- https://en.wikipedia.org/wiki/Induction_coil
This article is about the type of transformer that produces high-voltage pulses. For the more general electrical component, see Inductor. For the high-frequency heating coil, see induction heating. For the device in telephone sets, see hybrid coil. (https://upload.wikimedia.org/wikipedia/commons/thumb/2/23/Induktionsapparat_hg.jpg/260px-Induktionsapparat_hg.jpg)  Antique induction coil used in schools, from around 1900, Bremerhaven, Germany (https://upload.wikimedia.org/wikipedia/commons/thumb/8/8f/Induction_coil_cutaway.jpg/260px-Induction_coil_cutaway.jpg)  Induction coil showing construction, from 1920. An induction coil or "spark coil" (archaically known as an inductorium or Ruhmkorff coil[1] after Heinrich Rühmkorff) is a type of electrical transformer[2][3][4] used to produce high-voltage pulses from a low-voltage direct current (DC) supply.[1][5]  To create the flux changes necessary to induce voltage in the secondary coil, the direct current in the primary coil is repeatedly interrupted by a vibrating mechanical contact called an interrupter.[1]  Invented in 1836 by Nicholas Callan, with additional research by Charles Grafton Page and others,[1] the induction coil was the first type of transformer.  It was widely used in x-ray machines,[1][6] spark-gap radio transmitters,[1][6]  arc lighting and quack medical electrotherapy devices from the 1880s to the 1920s.  Today its only common use is as the ignition coils in internal combustion engines and in physics education to demonstrate induction.
https://en.wikipedia.org/wiki/Charles_Grafton_Page
english article
https://de.wikipedia.org/wiki/Charles_Grafton_Page
german article,for content comparison
Bedeutung(https://upload.wikimedia.org/wikipedia/commons/thumb/0/08/Motor_Page.jpg/220px-Motor_Page.jpg)  Kurbeltrieb-Elektromotor nach Page (https://upload.wikimedia.org/wikipedia/commons/thumb/f/f9/CGPagelocomotive.jpg/220px-CGPagelocomotive.jpg)  Elektrolokomotive von Charles G. Page, 1851 1836, fünf Jahre nach Entdeckung der elektromagnetischen Induktion durch Michael Faraday, erfand Charles Grafton Page die erste mit Hochspannung betriebene Induktionsspule. Deren Technik wurde Grundlage zahlreicher Zündungen im Automobilbau des 20. Jahrhunderts. 1838 konstruierte er einen elektromagnetischen Motor mit Kurbeltrieb, einen der ersten Elektromotoren der Technikgeschichte. Zu seinen weiteren Erfindungen gehören unter anderem der freiauslösende Leitungsschutzschalter, ein Drehspul-Galvanometer und eine Doppelhelix für den Induktionsmagnetismus. In den 1840er Jahren konstruierte er technische Ausrüstungsgegenstände für die Morsetelegrafie.
Page begann 1850 nahe Washington D.C. mit einem staatlichen Zuschuss von 20.000 Dollar den Bau einer von zwei Elektromotoren getriebenen Lokomotive. Die 15 kW starken Kurbeltriebmotoren bestanden prinzipiell aus jeweils zwei Spulen mit einem darin eingelassenen Stabanker. Dieser wurde durch wechselweises Einschalten der Spulen wie in einer Kolbendampfmaschine hin und her bewegt. Diese oszillierende (englisch reciprocating) Bewegung wurde mit einer Kurbelstange auf die Treibräder eines dreiachsigen Wagens übertragen. Gespeist wurden die Motoren aus einer gewaltigen, 50 Elemente umfassenden Batterie, die den Wagen auf ein Gewicht von 12 Tonnen brachte. Bei der Probefahrt am 29. April 1851 erreichte diese Lokomotive kurzzeitig eine Geschwindigkeit von 31 km/h, doch durchbrennende Isolierungen und unter den Erschütterungen brechende Batterieelemente führten dazu, dass die Fahrt nach 40 Minuten weit vor dem Ziel abgebrochen werden musste. Dabei handelte es sich um die zweite Elektrolokomotive, die unter freiem Himmel auf einer realen Bahnstrecke erprobt wurde. Zuvor hatte Robert Davidson seine Maschine ,,Galvani", die nach ähnlichen Prinzipien wie Pages Fahrzeug arbeitete, 1842 auf Gleisen in Schottland getestet. Frühere Konstruktionen von elektrogetriebenen Schienenfahrzeugen von Thomas Davenport (Vermont 1835) und Johann Philipp Wagner (Frankfurt am Main 1840) kamen nicht über den Status von unter Laborbedingungen getesteten Modellen hinaus.
Charles Grafton Page war Mitherausgeber des American Polytechnic Journal, er verfasste etwa 40 Arbeiten (meist Aufsätze) zu elektrotechnischen Themen. 2006 wurde er in die National Inventors Hall of Fame aufgenommen.
https://de.wikipedia.org/wiki/Doppelhelix
To more modern production process concepts,micro-/medio transformer/inductor size ,by Ex-Siemens-Engineer :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=erich+kaifler&IN=&CPC=&IC=&Submit=Search
More than 150 years retro search to find solutions from/of the Technical Future
Happy joy and fun  by save experiments and "rated/maximal output" observation and notice taking,protocol(e), wishing
OCWL
p.s.:
https://www.google.com/search?client=firefox-b-d&q=cortex
https://de.wikipedia.org/wiki/Ant%C3%B3nio_Egas_Moniz
https://www.google.com/search?client=firefox-b-d&q=seelenkoerper
Gehirn ,Seele : Un-/Sterblichkeit !?
https://www.zdf.de/dokumentation/zdfinfo-doku/geheimnisvolle-mumien-der-kriegerkoenig-und-die-koenigin-100.html
Research for solutions,by votivation and/or motivation is one "mind thing" ,but also important ,beside material tools and transformable material,
imaterial knowledge from the pioneers, motor-generator related ,especially DC-2-AC transducer :
https://de.wikipedia.org/wiki/Hertz_(Einheit)
https://de-m-wikipedia-org.translate.goog/wiki/Hertz_(Einheit)?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
A selection of different phenomena of different frequencies is in the List of Orders of Frequency list .
number of revolutionsTo edit In vibration measurement technology, the speed of a machine is given in Hertz, this is referred to as the rotational frequency .
Apart from that, the unit Hertz according to DIN 1301 should not be used for the speed.
Instead, the number of revolutions per minute is often given here:
  1Hz = 60/min
https://www.bfs.de/SharedDocs/Glossareintraege/DE/F/frequenz.html?view=renderHelp
https://www-bfs-de.translate.goog/SharedDocs/Glossareintraege/DE/F/frequenz.html?view=renderHelp&_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
        1 Hz = 1 swing/oscillation/cycle/circuit/RPS
        differring :
        high from low frequency
        positive from neutral to negative frequency,
        1/0/-1   f
        overtone from tone to undertone frequency
        and finally:
        for correct input/and/or output calculation
        1 Hz = ? signal/s or pulses per second ?
                                     This energeticforum participiant   BroMikey                          his/its scientifical/technical education degree ?
BroMikey  Platinum Member             Join Date: Jan 2013
Yesterday, 07:58 PM      Originally posted by Turion View Post  Another thing to consider is you could have 24 magnet rotor with 7 coils on each side of the rotor (14 coils). The frequency would be 7x24 = 168 x rpm. And you have to match your voltage to that.   This is how frequency is determined.
24 magnets cycling at 2800rpm =24 X 2800 = 67,200 times per minute the flux will strike a single coil core. But you want frequency, not pulses per minute so for this we need to go to a per second number. To do this divide 67,200 per minute by 60 seconds because we know that for every minute of time there are 60 divisions.
67,200 divided by 60 = 1120 pulses per second also known as 1120 cycles per second or 1120hz. Each section of core material found inside each coil gets struck by the same number of pulses as all 24 magnets pass by.
Therefore each of your generator coils will produce 1120 hz AC
For fun I am throwing in 2 video's (some old footage)
        1 Hertz Schwingung,
        bestehend aus zwei,2,Signalen oder auch genannt Pulsen,per Sekunde bzw. RPS
                            instead to calculate with only 1 signal or puls per second/cycle : and 50% REALITY lost ! ;D
                                                              " Hoffentlich kein Kretin-/Arschkriecher-Uni-Abschluss !  :D
                                                               Arschkriecher =PARASITEN stehen unter bedingungsfreien Abschuss-Schutz !"
  Ihr verstososzt tag-taeglich gegen Eure eigene Verfassung/Constitution,gegen die gemeinsame U.N. Charta !
Moege die globale Jugend ueber Euch richten,gerecht,kompensierend !
                                                               No HEAL-force = Anymore Title,Rank,Name importance and payment base !
Happy Wednesday( in anglo-/saxo-/phonic calendarium countries) work-flow wishing
( or Mittwoch,Quarta-feira,....)
OCWL
