The Musings of Smudge [Cyril Smith
Started by ramset, October 01, 2016, 05:40:52 AM
ramset
Here it is hoped some Of Smudges work can be shared and discussed for all to ponder, Not certain this is the best spot to post this particular musing
however it is a moderated section so hopefully the discussions will be relevant .
*Snip
Introduction
Graham Gunderson exhibited his "Magnetic Implosion Transformer" at the 2016 Energy
Conference. This device apparently delivered more power out than was supplied. Gunderson
admitted that he did not know why this was so, he had discovered the effect by accident while
experimenting. He did demonstrate waveforms pertaining to input and output, along with a
computed waveform of the flux through the secondary. The input waveform was of a special form
and the transformer output was converted to DC using synchronous rectification that effectively
produced a very short interrupt during which the flux changed sharply. This paper presents an
effect that could explain why Gunderson's device gave those results. Because of its importance in
offering means for extracting energy from ferromagnetic material it has been given the special name
"The Gunderson-Smith Effect".
A significant feature of the transformer is the rapid change of flux during the secondary interrupt
period. This suggested two avenues of enquiry, one being the possibility that energy could be
stored in the compression of the mylar film situated between the two core halves, and that mass
inertia might play its part in slowing down the change in compression when the flux changes value.
During the slow flux change between secondary interrupts the compression would follow the flux,
but in the fast flux change period the core faces would not move hence creating an imbalance
between the magnetic energy and the stored compression energy. After exploring this in some
detail it has been found that this imbalance does not lead to over-unity.
The second possibility relates to the frequency response of the core material where its permeability
can have different values for different rates-of-change of flux. This is much more rewarding and
the following sections explore this in more detail.
*end Snip
experiments are being considered here
http://www.overunityresearch.com/index.php?topic=3345.0
also being discussed here
http://www.energeticforum.com/renewable-energy/20546-magnetic-implosion-transformer-replication-3.html#post293226
respectfully
Chet K
Thanks Grandma
forest
The third and the simplest explanation is the magnetic induction at higher frequency, in other words magnetic induction do not diminish the source which created magnetic flux, one pulse of magnetic field can induce infinite current pulses in correct assembly.
I know it is against the current state of laws but I think the output of magnetic induction is the equal and opposite energy to the input energy if the Lenz law is used properly ( energy is taken from external force field). Every generator from the origin works that way.
forest
It was also described in Utkin document. Look for the magnetic induction when core permeability is manipulated at 90 degrees. I have constructed similar device many years ago but was unsuccessful to make it work properly because I was not experienced in disruptive discharge. I may post detailed explanation someday  but I'm sure Smudge will find it soon. It is very easy anyway - just a almost not inductive winding applied properly to proper ferrite core which create a nanoseconds big current pulses when capacitor discharge is flowing through it. The normal winding at slow frequency is so disrupted many times per period creating magnetic flux pulses not visible to the power source.
pomodoro
The capacitor equivalent would be a capacitor charged to say 10V. Now we (magically) remove  half of the capacitanceve . The voltage now doubles  to keep Q*C constant. The stored energy 0.5CV^2 has increased by 100%.  The inductor equivalent by Smudge is the same but uses currents instead. The word magic was used because in real life the capacitance is halved by separating the plates by more distance  requiring work from the person, the extra energy we get in the cap.
Should Grahams device really give extra energy it must also cool down the core as the extra energy must come from there as the inductance changes.
As usual, the scientific method requires replication, otherwise this one will also bite the dust  :( :(
allcanadian
@forest
QuoteThe third and the simplest explanation is the magnetic induction at higher frequency, in other words magnetic induction do not diminish the source which created magnetic flux, one pulse of magnetic field can induce infinite current pulses in correct assembly.
The fourth explanation almost never considered is the the Weber Force and the two cores separated by the dielectric (mylar) constitute two plates of a virtual capacitor. As Pomodoro implied... one moment it's there and in another it's not.
https://en.wikipedia.org/wiki/Weber_electrodynamics
AC
