Thanks to ALL for your help!!
a magnetic overunity base home mini Lab: what equipments & test-measure devices?
Started by raha, October 16, 2016, 08:01:52 AM
raha
this is an urgent help request to anyone with any skills-info. who can advice an unknown friend..
good time to all
before everything, i apologize for my weak english
and hereby my warm thanks for all who spend time for answers..
i want this post be as a "reference" for all who interest to over-unity Lab.'s Equipments, not just for me.
i am going to set a home test & measurement mini Lab. for Design, construction and operational experiences in the field of free energy/over unity based devices.
specially based on "magnetic/resonance" devices like or similar or based on these three devices for example:
1 - don smith generator
2 - kapagen
3 - beidini sg gen.
or any other devices that structural work with "magnetic/resonance"..
so 1 - what test / measuring equipments need for this mini home Lab. as we can say its minimum enough for starting the experiences?
and 2 - with what "ranges" Preferably? for example for measuring LCR or resonance frequency?
also 3 - especially for measurings "under load / on time" AC/DC/resonance/Gauss: pulses-amprages-voltages factors? this is very useful if we can measure ac/dc V & I and if is possible "resonance" under load, not with off power tests.
4 - for home made DIY "large amperage capacitors", is there any complete resource? or you suggest buying them ? one of problems for working on such devices is capacitors exploding under tests because of high currents.. what is your best advice to solve it?
i hope with the help of you and your answers, this post become an "useful reference" for all who interest to this field.
Here, on behalf of myself and all the people of Iran, I dedicate a poem by the great Persian poet to all of you members & visitors of this Community and the people of the world too:
"Human beings are members of a whole
In creation of one essence and soul
If one member is afflicted with pain
Other members uneasy will remain"..
Sa'adi
thanks of moderators and all those who gave me the opportunity for asking my questions here, and so all you dears answer them.
reza salahshour neiat
grid-tie solar power plants engineering design Supervisor in mashhad green energy management co., ltd.
dezeinstein
Well,
I figured out last night that Don Smith's generator works, and, I finally found out for sure why it works! It's been a long rocky road of trial and error until I stumbled upon one frequency measurement that made it all appear to be too good to be true, until I tested it out using low voltages and high frequency, with a mocked up mini smith coil, l1, l2 and the split coil utilizing diodes to test the theory that I found.
Let's see if anybody else could duplicate my theory. Take the measurements, frequencies and the formulas Don has given us, then use them to figure out what the frequency of the single L2 coil that uses the .047 uF cap does, and how it is related to the input frequency based upon Don's coil inductance that is written on B&W's site, well, cut in half that is, then the .2uF cap according to the same set of principles. You can't get an answer that makes sense, and that is until you take the answer you get and divide it by the carrier frequency which is 35.1kHZ.
In many true overunity systems, such as Aidas, Tiger, T-1000 and Arunas' systems, they all base their theories upon the same set of principles, and that is of an alogrythmic frequency which is a multiple of the carrier frequency, being the frequency we wish to be the resonant factor./
I call this the resonant factor , and yes you could call it whatever you want, but it is related to their systems, however they missed utilizing the second coil to add together the amperage and voltage as Dons shows by taking rectifiers and connecting the bottom and top coil in parallel. When this happens, the high frequency and the lower frequency allow the signals to duplicate, taking resonance to another level, then truly allowing the energy input to multiply times the base or carrier frequency provided. This happens just as Don says, and he does state that the higher the frequency is, the larger the amplification will be provided we put what the system needs together to function.
When i figured this out, I nearly blew up my entire garage with the arc that blasted through the capacitor bank where I convert the cold electricity back to conventional power. I am a high voltage distribution expert that has witnessed what incorrect combinations of utility transformers can do, and when i say they combine two forces, that of two different types of systems,. wye and delta, in an incorrect manner to create harmonics that will decimate anything in it's path without knocking out fuses. How does this do so if overunity is NOT possible? That was a question i had for an engineer and he insisted that he no matter what did not wish to speak about it because he said i lacked the knowledge to ever understand it. Well, guess what buddy.. I just have proven half the world wrong, proven Don Smith and Tesla right, and the rest of the establishment completely incorrect because of the brain dead manner they have tried to  hypnotize us all with in school to aid the greedy pockets in getting nothing but fatter.
Please do what I said if you see this post and try it out.. Just do me a favor, don't blame me if you weren't careful. Don was absolutely correct about the bloch wall area and it's incredible effect it gives. I have gained nearly 5000 times my input energy just by calculating resonance on both sides very carefully with a function generator, a few small rf coils, a few lousy caps , some diodes, and my super capacitor banks using two tuning capacitors and a wicked high frequency, using all types of signals. You can do this too, just use your mind with my theory.
It's pretty obvious it wasn't originally my finding, but I was the one who figure this out!!
Thanks,
Dezeinstein
Good Luck and please be careful!
Quote from: raha on October 16, 2016, 08:01:52 AM
good time to all
2 - kapagen
3 - beidini sg gen.
Sa'adi
Bob Smith
Quote from: dezeinstein on November 29, 2016, 09:41:15 PM
Well,
Thanks,
Dezeinstein
I'm not going to pretend I understand very much of this, but I appreciate it being shared. Hopefully there'll be some conversation to follow.
Bob
ayeaye
Don Smith did not publish the description of any working devices, he only provided some explanations, which are rather confusing  http://www.free-energy-info.com/Smith.pdf . And now one claims that one replicated the Don Smith device, but doesn't provide any details either.
What i personally think, magnetic field may provide the asymmetry to overcome lenz law. The magnetic field may be permanent, or provided by other coils or such, then the conditions when the magnetic field could enable to overcome the lenz law, may be what they (Don Smith and others) call resonance. What i agree with Don Smith is that the free power, if any, comes from the electrons, that is from the electrons spins.
Whatever device, i did not make it with a light bulbs in the input and output, this shows nothing. I did measure the power, but did also find out what really happens, which can give new knowledge even if there is no overunity. Which is a difficult and thorough work, so for the sake of goodness, make sure that at least the device is as simple as possible.
Turbo
